Can I just go ahead and install the eSIM of my local mobile carrier?
No, you need the physical eSIM from GL.
Then I will be able to use the local eSIM?
The eSIM feature inside the device isn't the same as in phones - you always need the physical eSIM which then gets the eSIM profiles saved on. You can use whatever eSIM you like then.
Read more here: esim — GL.iNet US
