X3000 rm520gl
May I know how can i completely reset the modem to factory setting on x3000 router?
Thank You
AT command for reset the Quectel modem:
AT+QPRTPARA=3
Hi Bruce,
Thanks for the reply.
So i used the GL.Inet WebUI, i enter your commands , and clicked send. I received an "OK" response.
But it doesnt seem like the modem is resetting. The old settings are still there.
Have you power cycled the router?
What did you configure in modem?
