The router X3000 is working fine but there is no display for the cellular modem LED
I have 5GSA connection
The LED for power, internet, 2.4G wifi and 5GHz wifi is working
Is there a modem.sh call that is turning it off?
Maybe other reason?
Did you reinstall the gl-sdk4-modem ipk?
where may i download it from?
Last time, I gave you an ipk to fix the modem traffic inversion problem
Ok, i have that ipk
It didn't fix the traffic inversion problem.
But let me install it again
No need to install again
try this
Does this ipk not fix the traffic inversion issue?
look at
AT+QGMR
Unfortunately, it didn't fix the issue...
Above shows the current status after trying the new ipk
To summarize, here's what i tried.
#opkg update
#opkg --force-reinstall install gl-sdk4-modem_git.2024.106.25196-10a9cdl-1_aarch64_cortex-a53.ipk
#cp /rom/etc/uci-defaults/99-set_modem.sh /etc/uci-defaults/
#/etc/uci-defaults/99-set_modem.sh
#/etc/init.d/modem restart
Then the modem only connects to 4G+
So i try 5GSA commands for modem
AT+QNWPREFCFG="mode_pref",AUTO
AT+QNWPREFCFG="nr5g_disable_mode",2
AT+QNWPREFCFG="nr5g_band",25:41:71:77
The modem now connects at 5GSA
I refresh the webpage
Result>
Same traffic issue
The cellular modem LED is off now
What is the module version number?
Not sure i understand the question
The firmware is v4.0
I tested the light and it worked
Please let me know the results of these commands
AT+QGMR
AT+QGDNRCNT?
AT+QGDCNT?
Note, i am using a RM521F modem
So, this was edited: /lib/functions/modem.sh
/ RM520NGL|
Change this to :
RM520NGL|
RM521FGL)
Modem is now recognized as RM521F and works great.
So perhaps, gl-sdk4-modem_git.2024.xyz.ipk needs to have the above information.
Here are the responses -
AT+QGMR = RM521FGLEAR05A02M4G_01.200.01.200
AT+QGDNRCNT? = +QGDNRCNT: 1646136024,9741506294
AT+QGDCNT? = +QGDCNT: 713117,1338252
Still doesn't work, after running the above changes again
gl-sdk4-modem_git-2024.156.32563-2f5ac8b-1_aarch64_cortex-a53.zip (400.2 KB)
Try this ipk
opkg --force-reinstall install /tmp/gl-sdk4-modem-xxxxxxxxxxxxxxxxxxxxxxxxxx
About the light not working
Please check whether the process exists
ps | grep modem
/etc/init.d/modem_signal restart
This is now working.
a. Traffic is reported correctly
b. Modem LED is lit
Some changes i made (only for my situation):-
a. From the ipk file (above), i edited /lib/functions/modem.sh
Changed
RM520NGL|
to :
RM520NGL|
RM521FGL)
Otherwise it only connects at 4G+
After the above change, it connects at 5GSA during bootup
Now it reports, traffic correctly.
b. I am running haproxy on port 443,80 as a load balancer and as a reverse proxy
(I could have use nginx for this but during upgrades that would get wiped. So
i decided to keep it separate using haproxy and it works great)
Since i had to move nginx to port 81 and 4431, i needed to edit
/usr/bin/modem_signal
Change the line from 127.0.0.1
to 127.0.0.1:81
Now modem LED works again.
Everything works after reboot.
Thank you
