Looks like X3000 is same chip as mt3000
That’s a lot of antennas.
There’s an XE3000 out there lurking as well…
4 for the 5g 2 for the wifi
Xe3000 is going to be a big challenge
No USB-C power port???
nope , dc in
not a big put off anyway, its not designed for hand held portability and there are big power banks with DC out port in the market
Too bad there’s no USB-C port.
What are the 4g/5g modules going to be ?
I’m looking forward to finding out the module options as well.
Not needed. I use these USB C to 12v barrel wires all the time. They work fine.
I see, is it got to pick the right voltage to trick the pd powerbank ?
It has a 12 volt trigger built into the usbC plug.
It will tell any power delivery system to supply 12 volts, including battery packs and very cheap usbC bricks.
I have had such a trigger for USB pd for a long time. The problem is that it destroys the universality of USB-C. There are a lot of USB c to c cables.
Another thing is that a USB-C device may not offer 12V but may offer the same Watts. Usually the converter can handle lower voltage and higher current.
In the case of a c to c cable, it all happens by itself, a bit magically.
There are different USB-C to DC55 triggers that max out at 20v or 12v.
I picked up the 100w variety (20v) for portable solar generators and stopped carrying extra power adaptors, just 65w/100w PD USB-C chargers and the USB-C to DC55 triggers. Very handy for several devices with the addition of adapters for non-DC5521 devices instead of buying one of each size (still 12v or 20v).
I also use a USB3 to DC55 (plus adapter) on my Spitz and skipped the extra cigarette plug cable. I even have USB3/C to cigarette plugs (12v), but never use them much.
DC55 adapter kit
https://www.amazon.com/Universal-Connectors-Adapter-Connector-Female/dp/B07CGDPJ19/ref=mp_s_a_1_14?keywords=dc55+adapter+kit&qid=1673459705&sr=8-14
The 20v triggers are fixed at 20v or floating ?
I plugged a 20v trigger into a 12v/13v fan once and it ran @ 20v. Unless the device uses 20v, I just use the selectable voltage converters or 12v triggers.
Not having to carry around so many AC adapters is a big plus with the 12v and 20v triggers, with everything capable of running off of standard power banks.
I have a 20000mah power bank with selectable 8.5v/12v/15v DC5521 output , USB and USB-C out which has come in handy with the Spitz for a full day runtime.
They should be Fixed.
With DC 9-36V input and detachable antennas, it looks like it may be handy on-the-go to service dozens of users/devices with a myriad of power sources when an outlet is not nearby.
The GL-X750 averages around 5w, but it will be interesting to see the power usage on the X3000 at full-tilt with 5g and 802.11ax.
X3000 maximum power consumption is ~15W, if including USB-A 5W power output, the total power is ~20W.
12V has better power efficiency than 5V input for such big power consumption, so we select 12V DC.
If this ends up being quectel rm520-GL or an even newer module it will be fantastic
