Hey all,
Somewhat new to this space. I'm locked to bands n41 and n71 SA and I can't get my upload over 10
I've attached a couple images. Looking for next steps
Hey all,
Do you know what speed should be available on these bands?
You might want to check here: https://www.cellmapper.net
@admon I'm really struggling to use that site. There's probably some concept I'm not understanding. Even in the app (Android) I'm not reliably finding towers
Here's another screenshot of what the spitz says is near me. Can you help?
@admon i was able to finally locate the top tower listed on my image, but I do not see any upload and download speeds on cm
I already saw that you had some discussion on Reddit about it, haha.
Afaik the Spitz does not connect to multiple towers. Just one and multiple bands if available there. Maybe @bruce can clarify.
You might test different towers by locking on them. For example, the n41 tower might provide better speed.
You can first move this SIM on your mobile phone. If there is no problem with this SIM of the phone's network speed, download a mobile APP called cellular-z to check how your mobile phone is connected to tower, band.
And move SIM back to the X3000 and try to lock on that tower.
