Hello, i have problem with the X300B-GPS . the GPS doesnt work …
Do you have any solution please?
thx
thx
Have you connected the GPS antenna?
of course it’s connected, i have try with 3 reboot with the GPS antenna connected on :
→ GPS connector = KO
→ 4G 1 with GPS antenna = KO
→ 4G 2 with GPS antenna = KO
i have check the connection on the board… what can i do more?
Ok, i have put the GPS antenna outdoors, the GPS have the status “valid” with good data.
It’s working on the local web adminitrator but i can’t send to the goodcloud interface the GPS data with the message : “device gps not found”.
Of course , the 4G and internet is ok.
Pls send me some details via pm or message.
it s send
thx alzhao
My GPS is valid, but in GoodCloud there is the message gps device gps not found!
Welcome to my univers ![]()
Developer said your issue should be resolved now. It is a problem of certificate.
great, now it’s ok for me thx!
I am having the same issue, where it states that the status is invalid. Can someone help me with how you were able to solve this problem? I have 13 of these devices, so it would be helpful to make sure I know where they are.
I’d suggest that you talk to our support via email.
