X570 V2 Spitz broken wrong polarity
I damaged my router by applying wrong polarity to the power input. Which component do I most likely have to replace?
The broken one…
You’ll need to get yourself an ammeter or something and go poking around the circuit board.
The broken one…
Thanks Sherlock
I found the faulty component. It heats up when I connect power. Can anyone tell me what this is?
It reads “05-720”
Thanks!
Looks like the controller of a SMPS (switch
mode power supply). But you have a good chance that some other components were destroyed too.
So don’t be disappointed if you exchange it and the Spitz still doesn’t work.
Yeah, I think it’s rather unlikely replacing it will fix it. I would try it as an exercise if I can find a cheap replacement of that 05-720 smd.
