X750 - 4G "connected", good IP etc. but does not route LAN traffic
A few days ago I posted GL.iNet - Connecting The World To Secure Wi-Fi on the bug tracker; no responses yet.
There are many posts here, on forum.openwrt.org and elsewhere about this and similar issues - modem connects but no internet connectivity. I’m not sure if this is a bug in qmi or elsewhere in openwrt, or a problem in the gl-inet factory config. But I’m sure there are many others struggling with this problem.
Any and all suggestions and pointers welcome, for me and others!
Thanks
Sean
Does your carrier allow for data sharing? Would a change in mtu help?
I have used many routers (MIFI, iphones, others) on Vodafone UK, so yes, it allows data sharing. How would i change mtu? Also, an mtu of 1500 is correct, isn’t it? And services like dns don’t use messages much shorter than 1500 bytes to I’d expect them to work if that were the problem.
BTW ny network config is:
config interface ‘modem_1_1_2’
option ifname ‘wwan0’
option service ‘fdd_lte’
option apn ‘Internet’
option proto ‘qmi’
option device ‘/dev/cdc-wdm0’
option username ‘web’
option password ‘web’
option metric ‘40’
option disabled ‘0’
Thanks
Sean
Hello,Sean
Can you describe how the problem came about? I remember dealing with the problem.
In case of a problem, you can use ifstatus modem_1_1_2_4 to check the status and see if the IP address is the same as the you using uqmi -d /dev/cdc-wdm0 --get-current-settings
Thanks
Luo
Thanks Luo. They look the same to me:
root@GL-X750:~# ifstatus modem_1_1_2_4
“up”: true,
“pending”: false,
“available”: true,
“autostart”: true,
“dynamic”: true,
“uptime”: 100,
“l3_device”: “wwan0”,
“proto”: “dhcp”,
“device”: “wwan0”,
“updated”: [
“addresses”,
“routes”,
“data”
“metric”: 40,
“dns_metric”: 0,
“delegation”: true,
“ipv4-address”: [
“address”: “10.22.154.7”,
“mask”: 28
“ipv6-address”: [
"ipv6-prefix": [
"ipv6-prefix-assignment": [
"route": [
		"target": "0.0.0.0",
		"mask": 0,
		"nexthop": "10.22.154.8",
		"source": "10.22.154.7\/32"
"dns-server": [
"dns-search": [
"inactive": {
	"ipv4-address": [
	"ipv6-address": [
	"route": [
	"dns-server": [
	"dns-search": [
"data": {
	"hostname": "GL-X750",
	"leasetime": 7200
root@GL-X750:~# uqmi -d /dev/cdc-wdm0 --get-current-settings
“pdp-type”: “ipv4”,
“ip-family”: “ipv4”,
“mtu”: 1500,
“ipv4”: {
“ip”: “10.22.154.7”,
“gateway”: “10.22.154.8”,
“subnet”: “255.255.255.240”
“ipv6”: {
"domain-names": {
root@GL-X750:~#
I think it’s also worth noting that the modem is sending data but receiving almost nothing:
Protocol: Unmanaged
Uptime: 0h 10m 27s
MAC-Address: 06:EE:4A:EF:FF:6F
RX: 610 B (2 Pkts.)
TX: 36.91 KB (433 Pkts.)
Actually the modem may be receiving data on the 4G side but isn’t forwarding it over IP into the router.
This situation is different from what I’ve seen before. Are you sure your firewall allows modem access to the Internet?
You can try manual dialing and use ttyUSB3 to see if the problem still exists.
Can you see /etc/config/firewall
I have been doing a factory reset between each set of tests, and I have not touched the firewall settings.
Here is a zipped archive of /etc/config/firewall: firewall.zip (919 Bytes)
Also, if there was a firewall issues I would expect to see data passing from the modem to the router but no further. As noted earlier, effectively no data appears to be coming from the modem.
I will try ttyUSB3 as you suggest.
Thanks
Aha! Using either /dev/ttyUSB2 or /dev/ttyUSB3 seems to work. Immediate connection, routing traffic as expected.
So I guess this is related to qmi? It seems that a factory reset and then booting with a Vodafone sim installed ends up with the modem configured to use /dev/cdc-wdm0 and not /dev/ttyUSB3
If I can do anything more to help diagnose or investigate further then just let me know.
Cheers
Sean
emmm,Is this a problem that comes up every time you use QMI?
This is the first time I have come across this problem
What is your modem model?
Can I have a look at it remotely?
Modem is an EP06.
I guess you just need an ssh session to take a look remotely; I can’t that up right now but I’ll try over the weekend. Can you give me an email address or some other way to send you credentials?
BTW, another complication: once the modem worked I installed the various packages I want to use, including luci-proto-qmi for testing in the future. After the next reboot the router came up using /dev/cdc-wdm0 to connect, and routed successfully. In order to confirm this, and especially to see if it’s the installation of luci-proto-qmi that makes the difference, I guess I will need to do ANOTHER factory reset, installs, etc. Another reason to leave to the weekend.
[email protected] is my email address.
Thanks
Luo
Dear all, ist there a solution for this issue?
Hi Tom
Yes, there is a solution… unfortunately I can’t remember exactly how it was fixed back in 2019.
I’m happily using two X750s over 4G. QMI is great once it’s working: my one suggestion is to use ‘Manual Setup’ (including the subsequent ‘More’ link). In my experience this is always needed after a modem reset. However, once everything is working it is stable through reboots, etc.
Talking of modem resets - my understanding is that a device reboot will NOT power-cycle or otherwise reset the modem. An actual power cycle does (obvs.) as does the ‘modem reset’ link. For testing purposes a power cycle is (slghtly) safer that a device reboot.
Good luck!
Sean
Hi Sean,
thank you for fast reply, i tried the manual setup, modem reset etc., but the X750 only works after swichting to ttyusb3, without qmi. Dont work with the qmi device.
Tom
Now it works:
After auto-setup just switch the proto to qcm, then it works.
Tom
