ChatGPT says that "AT+QPRTPARA=1 is not a complete command. It requires at least four parameters to be set, which define the maximum number of retransmissions allowed for a failed packet transmission, the maximum number of outstanding data packets that can be sent before waiting for an acknowledgement, the maximum time allowed for the modem to wait for an acknowledgement before retransmitting the packet, and the time delay between retransmissions of the same packet.
For example, the command AT+QPRTPARA=10,4,2000,2000 would set the maximum number of retransmissions to 10, the maximum number of outstanding data packets to 4, the maximum time allowed to wait for an acknowledgement to 2000 milliseconds, and the time delay between retransmissions to 2000 milliseconds.
It’s important to note that the optimal values for these parameters depend on the specific cellular network and the type of data being transmitted. Incorrectly setting these parameters can result in inefficient use of network resources or unreliable data transmissions."
Could you please explain what this command is expected to do?
