Will the newer Quectel EM12-G (LTE-A CAT 12) work the Spitz X750? Claims it’s drop-in compatible with stuff using the EM06.
Should not work out of the box. It is m2 interface.
Driver need to be added as well.
Oof. You’re correct. Back to the drawing board… Thanks!
Can you tell me which driver I have to install for the pci-e to m.2 interface (plug-ins) ? I have try it qith Goldenorb. It works but I like the gl.inet surface
