Hello Greetings,
May I know which port does the X750 v1 uses for 4G antenna? ( does it use both the SMA port, or is it 1 for wifi, and 1 for 4g)
Does anyone have any experience with directional 4G antenna fitted to x750?
Thanks.
Hello Greetings,
Thanks.
If this X750 is the default configuration, both SMA connectors are for 4G antennas.
SMA connectors for Cellular and WIFI are different, one is hole, anther is pin.
