X750v2 radios
@alzhao @bruce
Won’t it be damaged if used with one or two antennas temporarily disconnected?
I just need to test some config to check network strength etc.
No router will have issues by removing the antenna.
The router does not know about them.
Don’t connect or disconnect the antenna while the router is on and it should be OK.
I am not saying that it will damage the radio but better do the physical connection while the router is off.
@alzhao so after testing when I will connect them back everything will be fine?
Yes.
(supplement words...)
