I’m wondering if it is possible to connect my x750v2 to the velica mesh system using x750v2 as my main LTE router. I couldn’t find any info regarding this. Thanks.
It works but is double NAT.
Velica does not work in bridge mode with mesh.
Thank you. I’m assuming the same would be for any brand of mesh system then too, right? Also, can the xl750v2 be put in bridge mode only and use as straight lte modem?
No. In the current firmware it does not have LTE passthrough mode.
