I understand this is dead, but is it possible to pull in the api and web interface from GL-INET to run on a sotck openwrt install? I have a caswell x86 appliance I'm wanting to use as a travel router however I'd much rather use the GL-INET interface as it's great on my slate that I haveI and much better than the stock LUCI interface.
This is not possible unfortunately, it is propertairy.
But you have a theme being close which is luci-theme-argon, with luci-mod-dashboard.
The theme is not in the official openwrt repo.
Or this come close to what gl ui uses but i have no idea how it works:
That is oui.
Oui is a framework to design a ui similar as how gl ui is, it's also from the same developer ![]()
