XE3000 repeater 5 GHz iPhone does not work
Hi there,
I am currently testing an XE3000 (mostly to help @XXXLA) and I discovered that there is something odd with repeating specific 5 GHz channels.
Setup:
  • XE3000 with the newest stable firmware + DFS repeating allowed
  • iPhone 12 Pro Max (bought in Germany, set to Germany)
  • All is located in Germany
The XE3000 won’t find the 5 GHz hotspot of the iPhone.
SSID PHY Type RSSI Signal Quality Average Signal Quality Frequency Channel Information Size Security Cipher Maximum Speed Channel Width Channels Range BSS Type WPS Support 802.11 Standards Country Code
Test5GHz 802.11n/ac/ax -54 86 87.4 5,745 149 394 WPA2-PSK + WPA3-Personal CCMP 867 Mbps 80 MHz 147 - 163 Infrastructure No 802.11d/h/i DE
Since you can’t set a country code on the XE3000, I guess that the Wi-Fi module (/driver) isn’t able to see channels higher than a certain number or frequency?
Unfortunately, you can’t select the channel on an iPhone - you can only set compatibility mode, which will enforce 2.4 GHz (and it will work then)
@hansome This might be something worth a look.
Do you mean the hotspot of the iPhone broadcasting on channel 149?
Seems to be the default channel here in Germany, at least on my iPhone. The XE3000 is not able to see it.
I remember when country is set to DE, the 5G channel won’t beyond channel 140. But not sure if it’s true for xe3000, I’ll check with colleague tomorrow.
You can’t even set a country on the XE3000 :frowning:
Also the Hotspot from Android!! The same Problem…
What is the 5G WIFI bandwidth on the XE3000?
160 MHz
But I can see other 5 GHz Wi-Fi even if they have a different one.
Have you tried enable maximum compatibility on your iphone?I had a similar issue on my MT3000 and solved it by enable maximum compatibility on my iphone13.
As I said before this will work but it will force 2.4 GHz instead of 5 GHz.
So the main question is why the XE3000 isn’t able to see channel 149?
I also had the problem of not being able to see channel 149 on my MT3000. But when I waited for 1 minute and refreshed the list of available networks, I was able to see it.
I’ll try again, but I am pretty sure that I waited long enough :smile:
I’ll keep you informed!
@Dipin I tried it again and waited 5 minutes. All other devices here can discover my iPhone sending on channel 149 - but the XE3000 still does not recognize it. Any idea?
– Edit –
It tried it with my AX1800, and it was perfectly aware of the iPhone on CH 149.
– Edit2 –
Now I am sending Wi-Fi on my AX1800, on CH 149 as well.
AX1800-CH149 802.11n/ac/ax -46 90 91,1 5,745 149 250 WPA2-PSK CCMP 867 Mbps 80 MHz 147 - 163 Infrastructure No 802.11d/e/i/y US
So the country code of the AX1800 is US by default. When we change it to DE the channel list will not list channel 149. That might be the problem here.
Forcing it won’t work:
Fri Sep  8 08:31:24 2023 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Fri Sep  8 08:31:24 2023 daemon.notice hostapd: Frequency 5745 (primary) not allowed for AP mode, flags: 0x1
Fri Sep  8 08:31:24 2023 daemon.err hostapd: Primary frequency not allowed
Fri Sep  8 08:31:24 2023 daemon.warn hostapd: wlan1: IEEE 802.11 Configured channel (149) or frequency (5745) (secondary_channel=1) not found from the channel list of the current mode (2) IEEE 802.11a
Fri Sep  8 08:31:24 2023 daemon.warn hostapd: wlan1: IEEE 802.11 Hardware does not support configured channel
Fri Sep  8 08:31:24 2023 daemon.err hostapd: Could not select hw_mode and channel. (-3)
Fri Sep  8 08:31:24 2023 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->DISABLED
Fri Sep  8 08:31:24 2023 daemon.notice hostapd: wlan1: AP-DISABLED
Fri Sep  8 08:31:24 2023 daemon.err hostapd: wlan1: Unable to setup interface.
In Germany channel 149 is only allowed for registered service providers or devices with less power - like a personal hotspot on your phone. So, while it’s not allowed to send on this channel with a router - it should be still possible to connect to.
Maybe there is a bug within the XE3000 which will ignore those channels by default if the countrycode of the Wi-Fi is DE??
I confirmed the issue of XE3000 channel 149 with R&D,it should be that the Band4(149-165) of XE3000 is not open in DE.
So something that could be fixed? Or something that is simply impossible?
The XE should see 149, since it’s perfectly allowed to use it. But it does not see it.
afaik the channels of band 3: 5725 - 5875 MHz ( 147,
151, 155, 167) are allowed in GB only within EU.
Main problem: A travel router (which is used to … travel) should be able to see all bands or you should be able to modify the country. Both does not work currently.
So, just a quick follow-up:
We found the main cause - which is that the country code for the XE3000 (and X3000 as well) is hard-coded inside the configuration partition. So it’s nothing you can easily change - at least not without knowing the commands.
After trying with @Dipin we were able to change the country code and enable the XE3000 to see Wi-Fi band 149. So that’s some case for R&D now.
Unfortunately, I cannot share the commands with the community as they may affect regulations. We will therefore have to wait for an official solution.
