Hello all.
I’ve been trying to get my AR300M16 to connect to a captive portal network but I can’t seem to make it work. I’ve tried a lot of the suggestions I found in the forum and no luck yet.
My firmware version is 3.203. I tried upgrading to 3.211 and had the same issue but with a different error message (“Wrong key”, which I found out that it is a bug in that firmware).
What I’m trying is:
- Connect the AR300M16 to the laptop via ethernet (LAN port)
- Connect to the captive portal network from a laptop
- Authenticate the laptop using the captive portal’s authentication popup
- Grab the laptop’s wifi card mac address
- Update the
Your Router (WAN)to match the laptop’s mac address - Disable the
DNS Rebinding Attach Protection - Disconnect the laptop from the captive portal network
- Find the network in the Internet>Wi-fi section
- Press join
After a long while I get an error saying: ERROR: Time out
I looked at the logs and here’s what it ends with:
Thu Jul 1 11:11:20 2021 user.info : saved ssid ignore: Open Sesame 0
Thu Jul 1 11:11:20 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=Open Sesame, encryption=none, bssid=8E:2A:A8:47:06:97, wds=0, device=radio0, identity=, channel=11
Thu Jul 1 11:11:20 2021 user.info : [ 3043] gl-wifi-core>> bIsStaEnabled=1
Thu Jul 1 11:11:20 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Jul 1 11:11:20 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Jul 1 11:11:20 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Jul 1 11:11:20 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Jul 1 11:11:20 2021 kern.info kernel: [ 3342.163490] device wlan0 left promiscuous mode
Thu Jul 1 11:11:20 2021 kern.info kernel: [ 3342.168284] br-lan: port 2(wlan0) entered disabled state
Thu Jul 1 11:11:20 2021 daemon.notice netifd: Network device 'wlan0' link is down
Thu Jul 1 11:11:21 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Jul 1 11:11:21 2021 daemon.notice netifd: radio0 (22396): sh: /usr/bin/ovs-vsctl: not found
Thu Jul 1 11:11:21 2021 kern.info kernel: [ 3343.473506] br-lan: port 2(wlan0) entered blocking state
Thu Jul 1 11:11:21 2021 kern.info kernel: [ 3343.479116] br-lan: port 2(wlan0) entered disabled state
Thu Jul 1 11:11:21 2021 kern.info kernel: [ 3343.485082] device wlan0 entered promiscuous mode
Thu Jul 1 11:11:21 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:12:73:c3 and ssid "GL-AR300M-3c3-NOR"
Thu Jul 1 11:11:22 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Thu Jul 1 11:11:22 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Jul 1 11:11:23 2021 daemon.notice wpa_supplicant[22633]: Successfully initialized wpa_supplicant
Thu Jul 1 11:11:23 2021 daemon.notice netifd: Interface 'wwan' is enabled
Thu Jul 1 11:11:24 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:11:24 2021 kern.info kernel: [ 3345.594690] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:11:24 2021 kern.info kernel: [ 3345.613911] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:11:24 2021 kern.info kernel: [ 3345.770564] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:11:24 2021 kern.info kernel: [ 3345.890562] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:11:24 2021 kern.info kernel: [ 3346.010565] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:11:26 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:11:26 2021 kern.info kernel: [ 3348.105110] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:11:26 2021 kern.info kernel: [ 3348.124319] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:11:26 2021 kern.info kernel: [ 3348.240572] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:11:26 2021 kern.info kernel: [ 3348.350564] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:11:26 2021 kern.info kernel: [ 3348.460569] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:11:29 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:11:29 2021 kern.info kernel: [ 3351.455669] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:11:29 2021 kern.info kernel: [ 3351.475001] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:11:30 2021 kern.info kernel: [ 3351.600573] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:11:30 2021 kern.info kernel: [ 3351.710559] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:11:30 2021 kern.info kernel: [ 3351.820559] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:11:30 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Open Sesame" auth_failures=1 duration=10 reason=CONN_FAILED
Thu Jul 1 11:11:30 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:11:32 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:11:34 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:11:35 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:11:40 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: CTRL-EVENT-SSID-REENABLED id=0 ssid="Open Sesame"
Thu Jul 1 11:11:42 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:11:42 2021 kern.info kernel: [ 3363.825619] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:11:42 2021 kern.info kernel: [ 3363.844820] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:11:42 2021 kern.info kernel: [ 3363.960594] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:11:42 2021 kern.info kernel: [ 3364.070573] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:11:42 2021 kern.info kernel: [ 3364.180600] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:11:42 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Open Sesame" auth_failures=2 duration=20 reason=CONN_FAILED
Thu Jul 1 11:11:44 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:11:51 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:11:51 2021 user.info : [ 1893] gl-wifi-core>> Restart wifi...
Thu Jul 1 11:11:52 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Jul 1 11:11:52 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Jul 1 11:11:52 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Jul 1 11:11:52 2021 daemon.err wpa_supplicant[22634]: Failed to stop hostapd AP interfaces
Thu Jul 1 11:11:52 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Jul 1 11:11:52 2021 daemon.notice wpa_supplicant[22634]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Thu Jul 1 11:11:52 2021 daemon.notice wpa_supplicant[22634]: wlan-sta: CTRL-EVENT-TERMINATING
Thu Jul 1 11:11:52 2021 kern.info kernel: [ 3373.771990] device wlan0 left promiscuous mode
Thu Jul 1 11:11:52 2021 kern.info kernel: [ 3373.776863] br-lan: port 2(wlan0) entered disabled state
Thu Jul 1 11:11:52 2021 daemon.notice netifd: Interface 'wwan' is disabled
Thu Jul 1 11:11:54 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Jul 1 11:11:54 2021 daemon.notice netifd: radio0 (23190): sh: /usr/bin/ovs-vsctl: not found
Thu Jul 1 11:11:54 2021 kern.info kernel: [ 3376.263556] br-lan: port 2(wlan0) entered blocking state
Thu Jul 1 11:11:54 2021 kern.info kernel: [ 3376.269165] br-lan: port 2(wlan0) entered disabled state
Thu Jul 1 11:11:54 2021 kern.info kernel: [ 3376.275036] device wlan0 entered promiscuous mode
Thu Jul 1 11:11:54 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:12:73:c3 and ssid "GL-AR300M-3c3-NOR"
Thu Jul 1 11:11:55 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Thu Jul 1 11:11:55 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Jul 1 11:11:55 2021 daemon.notice wpa_supplicant[23413]: Successfully initialized wpa_supplicant
Thu Jul 1 11:11:55 2021 daemon.notice netifd: Interface 'wwan' is enabled
Thu Jul 1 11:11:56 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:11:56 2021 kern.info kernel: [ 3377.886400] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:11:56 2021 kern.info kernel: [ 3377.905668] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:11:56 2021 kern.info kernel: [ 3378.020560] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:11:56 2021 kern.info kernel: [ 3378.130579] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:11:56 2021 kern.info kernel: [ 3378.250561] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:11:58 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:11:58 2021 kern.info kernel: [ 3380.345248] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:11:58 2021 kern.info kernel: [ 3380.364474] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:11:58 2021 kern.info kernel: [ 3380.490576] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:11:59 2021 kern.info kernel: [ 3380.610622] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:11:59 2021 kern.info kernel: [ 3380.720583] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:12:02 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:12:02 2021 kern.info kernel: [ 3383.715808] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:12:02 2021 kern.info kernel: [ 3383.735003] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:12:02 2021 kern.info kernel: [ 3383.850560] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:12:02 2021 kern.info kernel: [ 3384.010607] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:12:02 2021 kern.info kernel: [ 3384.120564] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:12:02 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Open Sesame" auth_failures=1 duration=10 reason=CONN_FAILED
Thu Jul 1 11:12:08 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:12:12 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: CTRL-EVENT-SSID-REENABLED id=0 ssid="Open Sesame"
Thu Jul 1 11:12:14 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: SME: Trying to authenticate with 8e:2a:a8:47:06:97 (SSID='Open Sesame' freq=2462 MHz)
Thu Jul 1 11:12:14 2021 kern.info kernel: [ 3396.114999] wlan-sta: authenticate with 8e:2a:a8:47:06:97
Thu Jul 1 11:12:14 2021 kern.info kernel: [ 3396.134529] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 1/3)
Thu Jul 1 11:12:14 2021 kern.info kernel: [ 3396.250561] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 2/3)
Thu Jul 1 11:12:14 2021 kern.info kernel: [ 3396.360575] wlan-sta: send auth to 8e:2a:a8:47:06:97 (try 3/3)
Thu Jul 1 11:12:14 2021 kern.info kernel: [ 3396.480651] wlan-sta: authentication with 8e:2a:a8:47:06:97 timed out
Thu Jul 1 11:12:14 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="Open Sesame" auth_failures=2 duration=20 reason=CONN_FAILED
Thu Jul 1 11:12:17 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:12:18 2021 daemon.notice hostapd: handle_probe_req: send failed
Thu Jul 1 11:12:23 2021 user.info : [ 817] gl-sdk>> wifi_join return=-5, channel=-1
Thu Jul 1 11:12:23 2021 user.info : [ 1893] gl-wifi-core>> Restart wifi...
Thu Jul 1 11:12:23 2021 daemon.notice netifd: Interface 'wwan' is disabled
Thu Jul 1 11:12:23 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Jul 1 11:12:23 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Jul 1 11:12:23 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Jul 1 11:12:23 2021 daemon.err wpa_supplicant[23420]: Failed to stop hostapd AP interfaces
Thu Jul 1 11:12:23 2021 daemon.notice wpa_supplicant[23420]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Thu Jul 1 11:12:23 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Jul 1 11:12:23 2021 daemon.notice wpa_supplicant[23420]: wlan-sta: CTRL-EVENT-TERMINATING
Thu Jul 1 11:12:23 2021 kern.info kernel: [ 3405.462275] device wlan0 left promiscuous mode
Thu Jul 1 11:12:23 2021 kern.info kernel: [ 3405.466984] br-lan: port 2(wlan0) entered disabled state
Thu Jul 1 11:12:25 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Jul 1 11:12:25 2021 daemon.notice netifd: radio0 (23993): sh: /usr/bin/ovs-vsctl: not found
Thu Jul 1 11:12:25 2021 kern.info kernel: [ 3407.442020] br-lan: port 2(wlan0) entered blocking state
Thu Jul 1 11:12:25 2021 kern.info kernel: [ 3407.447632] br-lan: port 2(wlan0) entered disabled state
Thu Jul 1 11:12:25 2021 kern.info kernel: [ 3407.453508] device wlan0 entered promiscuous mode
Thu Jul 1 11:12:25 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Thu Jul 1 11:12:27 2021 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=11 sec=7 based on overlapping BSSes
Thu Jul 1 11:12:27 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 94:83:c4:12:73:c3 and ssid "GL-AR300M-3c3-NOR"
Thu Jul 1 11:12:27 2021 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Thu Jul 1 11:12:27 2021 kern.info kernel: [ 3408.945916] br-lan: port 2(wlan0) entered blocking state
Thu Jul 1 11:12:27 2021 kern.info kernel: [ 3408.951477] br-lan: port 2(wlan0) entered forwarding state
Thu Jul 1 11:12:27 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Jul 1 11:12:27 2021 daemon.notice netifd: Network device 'wlan0' link is up
Any advise?
