(yet another) tailscale ask for help
Hi. Just bought a Beryl MT-3000, mainly for its built-in tailscale support.
Tl;Dr: although I managed to get it registered as authorized machine in my tailnet, I cannot access any other machine on my tailnet from devices connected to it.
I know tailscale integration in beta, but I struggle to get it running at all – to my surprise, since I got tailscale working now for >20 devices and several tailnets. Now I feel like an idiot. Heres what Ive tried:
  • factory-reset the router + update firmware to 4.7.0
  • setup tailscale through router GUI incl. the binding link flow > tailscale admin console
  • tried all variations with LAN/WAN access enabled/disabled
  • approved subnet routing
  • checked LuCI for updates
  • checked tailscale CLI output through SSH, no errors
Now I ended up here
  • no tailscale = everything works fine
  • with tailscale on, I can access public internet sites, but nothing on my tailnet
  • with tailscale on + my LAN router as exit node, I cannot even access internet sites
I tested the same tailnet with other devices and both ways with and without my LAN router as exit node work just fine.
Can someone help me troubleshoot?
:slight_smile:
Could you elaborate more on what you're trying to achieve?
Can you not ping the other devices using their Tailscale IP?
Thank you and apologies, if the topology wasn`t clear.
In a nutshell: I want to connect from a client (e.g. a laptop) inside a remote WiFi LAN made by the GL-MT3000 to a service (e.g. password manager) in my Home LAN through my tailnet.
Since I cannot install tailscale directly on that laptop I would like to use the tailnet integration on the GL-MT3000.
I hope that simplified sketch helps:
Ping to the service or the OPNsense router (both WAN IP and LAN 10.12.22.1) time out.
Traceroute starts and ends with the router:
traceroute to 10.12.22.1 (10.12.22.1), 64 hops max, 40 byte packets
 1  console.gl-inet.com (192.168.8.1)  6.312 ms  7.145 ms  7.305 ms
 2  * * *
Remote devices outside the GL-MT3000 network running tailscale client directly can connect to all tailnet machines as expected. So I assume the error must be on the GL-MT3000 end.
You can have a look at that post.
tldr:
First, you need to go into LUCI and goto the firewall and edit the "wan" zone.. goto "advanced settings" and add "tailscale0" to the "covered devices" then save & apply. This will instantly make Tailscale function as intended.
Thanks a ton! That indeed did the trick.
I hope this get`s ironed out during the beta.
