ZeroTier Issue on Slate7 GL-BE3600
Good afternoon,
My Slate7 came in a few days ago and I have been setting it up to be my default travel device instead of my Beryl AX (GL-MT3000).
The only problem is that I am having issues with the ZeroTier setup. I was able to add it to my account and I have it setup to "Allow Remote Access LAN", except there is some issue that does not allow it to actually access the devices.
I can ping the subnet and do a traceroute, but if I try to access anything via HTTPS or SMB, it just times out. The routes are configured correctly as the Beryl AX is able to do this with ease.
I have confirmed that "Allow Remote Access WAN" does work -- I added the Slate 7's subnet in the ZT routes and that works just fine -- just not the opposite way around (Slate 7 LAN -> Home Subnet).
Has anyone else run into this issue?
I tested on my Slate 7 and it is no problem.
Zerotier on iPhone, which can be remotely connected to Zerotier on Slate 7, and Sabma on Slate 7 can be accessed on iPhone:
