Zerotier issue
Zerotier route fails to get into the working config
After troubleshooting here is my inputs:
logs shows that the problem is related to how OpenWrt initializes ZeroTier and its static routes, rather than a problem with ZeroTier connectivity itself.
What the logs reveal
NOVEMBER 9, 2026
ZeroTier operational
  • 19:24:40 — WAN connected
    Howe obtains 192.168.86.128 from its upstream router.
  • 19:25:20 — ZeroTier interface activated
    ztre47hu7a becomes available and OpenWrt marks the interface as up.
  • 19:25:20 — ZeroTier control plane starts
    ZeroTier begins initialization at approximately the same time OpenWrt brings up its interface.
  • 19:25:20 — Firewall reloaded
    OpenWrt reloads its firewall because the ZeroTier interface came up.
There's no explicit route-installation error in these log lines.
However, I have confirmed that OpenWrt knows about the four static routes while Linux did not have them installed.
My working explanation
A possible sequence is:
  1. OpenWrt detects the ZeroTier interface.
  2. OpenWrt attempts to configure its static routes.
  3. ZeroTier has not finished initializing the interface or assigning its address.
  4. The routes aren't installed.
  5. ZeroTier finishes initializing, but the missing routes aren't retried.
This is a plausible startup race, not yet a proven firmware defect.
I have to reload the router with ssh to get it working.
GL.iNet GL-MT3000
OpenWrt 21.02-SNAPSHOT r15812+926-46b6ee7ffc
kernel 5.4.211
Thank you for the detailed investigation and startup timeline.
Could you please share the following details to help us reproduce and investigate the issue?
  1. Please share the GL.iNet firmware version shown in the router’s web admin panel.
  2. Could you share a screenshot or configuration snippet of the four affected routes?
  3. Could you please brief steps to reproduce the issue, and whether it happens consistently.
If you still have the original logs and route table output from your investigation, could you please send them to us via private message?
Thank you for your support and understanding.
How to send private messages:
