Hi i have a MT-1300 that does not see the usb ZTE 4g when i plug it in.
I have already install latest beta version 3.215 beta1 to try but same, not seeing it.
Thanks
Thanks
Witch WLAN channel is set inside the ZTE? Depending on the region it could be the reason why the Beryl can’t see the ZTE. Something between 1 and 11 should work.
Just a first thought.
It works as usb modem so has no wifi settings in ZTE.
