I am trying to connect my GL-AC-1200 router through the normal config using my ZTE Mobley cellular modem model VM6200 from ATT connected through the USB port as a tether, the router is not recognizing the modem.
I bought this for its compatibility with 3G/4G.
Is there some specific add in app or settings I must configure?
The ZTE modem will connect only as a wifi repeater but this is not how I wanted to use the router/modem configuration.
The ZTE Mobley works fine connected to an ASUS router via USB and has been found to work with Tomato and DD-WRT so I would think it would work on your software.
I did upgrade firmware to 4.3.12
