Otherwise just say it in Chinese directly.... I didn't understand what "background filter" is
Hello! Turning off the video in Teams and then turning it back on, or turning on the blurred background and then turning it off, still did not solve the screen lag issue.
Can you provide a screen recording? Also, I mean disabling the camera function on KVM.
Any movement on USB Audio for the Comet 5G?
The firmware update you provided last time works very well. There are no issues for now, and I also tested screen sharing with no problems.
- Microphone popping is solved only for WebRTC (native) but it’s not working well on WebRTC and FEC (same popping, breaking).
- WebRTC (native) stream quality is very bad
- Absolute mouse issue still exist
