15% packet loss from MT300N after fresh reset!?
as mentioned in another thread already. My GLinet router makes my internet almost unusable.
Slow speeds and ping times
I hope these ping times are not normal. Because then i will definitely run far away from GLient products. :joy:
I know that i get sometimes for maybe 30 seconds pings of 3ms to the router. So i know it is possible. But how? Does everybody has these numbers or is it just me?
That’s how it looks after a fresh factory reset with only one device connected:
And sometimes it looks like this:
Surfing is no fun at all… :frowning_face:
On the WAN side i use a external USB Wifi: TL-WN722N. But that isn’t installed after a fresh factory reset. So i don’t think it is the reason.
What is the reason for these time outs? Is my air not compatible with wifi? :joy:
I already spend so much time with this router… i am not sure if it’s worth more :frowning:
Let me know if i can post or do anything more to help to find the problem.
Here is the syslog:
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.497765] usbcore: registered new interface driver usbserial
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.503896] usbcore: registered new interface driver usbserial_generic
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.510648] usbserial: USB Serial support registered for generic
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.534757] wireguard: WireGuard 0.0.20191012 loaded. See www.wireguard.com for information.
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.543394] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.621141] xt_time: kernel timezone is -0000
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.630245] usbcore: registered new interface driver cdc_ether
Thu Oct  8 11:11:02 2020 kern.info kernel: [   20.643415] usbcore: registered new interface driver cdc_ncm
Thu Oct  8 11:11:02 2020 kern.info kernel: [   21.172215] usbcore: registered new interface driver cp210x
Thu Oct  8 11:11:02 2020 kern.info kernel: [   21.177958] usbserial: USB Serial support registered for cp210x
Thu Oct  8 11:11:02 2020 kern.info kernel: [   21.201401] usbcore: registered new interface driver huawei_cdc_ncm
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.480555] PPP generic driver version 2.4.2
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.498668] PPP MPPE Compression module registered
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.513236] NET: Registered protocol family 24
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.528827] usbcore: registered new interface driver qmi_wwan
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.550813] usbcore: registered new interface driver rndis_host
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.573956] usbcore: registered new interface driver sierra
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.579715] usbserial: USB Serial support registered for Sierra USB modem
Thu Oct  8 11:11:02 2020 kern.info kernel: [   22.633224] usbcore: registered new interface driver sierra_net
Thu Oct  8 11:11:02 2020 kern.info kernel: [   23.303140] usbcore: registered new interface driver option
Thu Oct  8 11:11:02 2020 kern.info kernel: [   23.308901] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Oct  8 11:11:02 2020 kern.info kernel: [   23.466441] usb 1-1: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
Thu Oct  8 11:11:02 2020 kern.info kernel: [   23.474027] usbcore: registered new interface driver ath9k_htc
Thu Oct  8 11:11:02 2020 user.info kernel: [   23.509483] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Oct  8 11:11:02 2020 kern.info kernel: [   23.999948] usb 1-1: ath9k_htc: Transferred FW: ath9k_htc/htc_9271-1.4.0.fw, size: 51008
Thu Oct  8 11:11:02 2020 kern.info kernel: [   24.250547] ath9k_htc 1-1:1.0: ath9k_htc: HTC initialized with 33 credits
Thu Oct  8 11:11:02 2020 kern.info kernel: [   24.526558] ath9k_htc 1-1:1.0: ath9k_htc: FW Version: 1.4
Thu Oct  8 11:11:02 2020 kern.info kernel: [   24.532232] ath9k_htc 1-1:1.0: FW RMW support: On
Thu Oct  8 11:11:02 2020 kern.debug kernel: [   24.537007] ath: EEPROM regdomain: 0x809c
Thu Oct  8 11:11:02 2020 kern.debug kernel: [   24.537011] ath: EEPROM indicates we should expect a country code
Thu Oct  8 11:11:02 2020 kern.debug kernel: [   24.537017] ath: doing EEPROM country->regdmn map search
Thu Oct  8 11:11:02 2020 kern.debug kernel: [   24.537022] ath: country maps to regdmn code: 0x52
Thu Oct  8 11:11:02 2020 kern.debug kernel: [   24.537028] ath: Country alpha2 being used: CN
Thu Oct  8 11:11:02 2020 kern.debug kernel: [   24.537032] ath: Regpair used: 0x52
Thu Oct  8 11:11:02 2020 kern.info kernel: [   24.582179] ieee80211 phy0: Atheros AR9271 Rev:1
Thu Oct  8 11:11:04 2020 daemon.notice procd: /etc/rc.d/S18firewall_gl: uci: Entry not found
Thu Oct  8 11:11:06 2020 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Oct  8 11:11:06 2020 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: started, version 2.80test2 cachesize 150
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: DNS service limited to local subnets
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: using local addresses only for domain test
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: using local addresses only for domain onion
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: using local addresses only for domain localhost
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: using local addresses only for domain invalid
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: using local addresses only for domain bind
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: using local addresses only for domain lan
Thu Oct  8 11:11:07 2020 daemon.warn dnsmasq[1384]: no servers found in /tmp/resolv.conf.auto, will retry
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: read /etc/hosts - 4 addresses
Thu Oct  8 11:11:07 2020 daemon.info dnsmasq[1384]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: tunnel
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: Network device
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: bridge
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: veth
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: macvlan
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: 8021ad
Thu Oct  8 11:11:12 2020 user.notice : Added device handler type: 8021q
Thu Oct  8 11:11:14 2020 daemon.notice procd: /etc/rc.d/S21initswitch: uci: Entry not found
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.153572] TX_BCN DESC a6fe1000 size = 320
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.157891] RX[0] DESC a6feb000 size = 2048
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.162574] RX[1] DESC a6fec000 size = 1024
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.263394] prepare to get e2p access------------
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.268440] E2pAccessMode=2
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.272417] cfg_mode=9
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.274808] cfg_mode=9
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.277202] wmode_band_equal(): Band Equal!
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.285742] APSDCapable[0]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.288659] APSDCapable[1]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.291587] APSDCapable[2]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.294502] APSDCapable[3]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.297418] APSDCapable[4]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.300344] APSDCapable[5]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.303260] APSDCapable[6]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.306191] APSDCapable[7]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.309107] APSDCapable[8]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.312033] APSDCapable[9]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.314948] APSDCapable[10]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.317952] APSDCapable[11]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.320970] APSDCapable[12]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.323975] APSDCapable[13]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.326978] APSDCapable[14]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.329982] APSDCapable[15]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.332996] default ApCliAPSDCapable[0]=0
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.722717] Key1Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.728199] Key1Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.733690] Key1Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.739354] Key2Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.744852] Key2Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.750344] Key2Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.756015] Key3Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.761511] Key3Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.766994] Key3Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.772684] Key4Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.778168] Key4Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.783666] Key4Str is Invalid key length(0) or Type(1)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.820183] load fw image from fw_header_image
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.824711] AndesMTLoadFwMethod1(2548)::pChipCap->fw_len(63536)
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.830719] FW Version:
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.830724] _
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.833198] e
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.834791] 2
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.836383] _
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.837977] m
Thu Oct  8 11:11:19 2020 kern.warn kernel: [   43.839571] p
Thu Oct  8 11:11:20 2020 authpriv.info dropbear[1869]: Not backgrounding
Thu Oct  8 11:11:22 2020 user.notice root: drv_ralink_cleanup
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'lan' is enabled
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'lan' is setting up now
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'lan' is now up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'loopback' is enabled
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'loopback' is setting up now
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'loopback' is now up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'wan' is enabled
Thu Oct  8 11:11:30 2020 daemon.notice netifd: bridge 'br-lan' link is up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'lan' has link connectivity
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Network device 'eth0' link is up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: VLAN 'eth0.1' link is up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Network device 'lo' link is up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'loopback' has link connectivity
Thu Oct  8 11:11:30 2020 daemon.notice netifd: VLAN 'eth0.2' link is up
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'wan' has link connectivity
Thu Oct  8 11:11:30 2020 daemon.notice netifd: Interface 'wan' is setting up now
Thu Oct  8 11:11:32 2020 daemon.notice netifd: wan (2300): udhcpc: started, v1.28.3
Thu Oct  8 11:11:33 2020 daemon.notice netifd: wan (2300): udhcpc: sending discover
Thu Oct  8 11:11:33 2020 daemon.notice netifd: Network device 'ra0' link is up
Thu Oct  8 11:11:34 2020 daemon.notice procd: /etc/init.d/network: uci: Entry not found
Thu Oct  8 11:11:36 2020 daemon.notice netifd: wan (2300): udhcpc: sending discover
Thu Oct  8 11:11:37 2020 daemon.err rmmod: module is not loaded
Thu Oct  8 11:11:38 2020 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Thu Oct  8 11:11:38 2020 daemon.info dnsmasq[1384]: exiting on receipt of SIGTERM
Thu Oct  8 11:11:39 2020 daemon.notice netifd: wan (2300): udhcpc: sending discover
Thu Oct  8 11:11:39 2020 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Thu Oct  8 11:11:39 2020 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: started, version 2.80test2 cachesize 150
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: DNS service limited to local subnets
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC no-ID loop-detect inotify dumpfile
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq-dhcp[2836]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: using local addresses only for domain test
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: using local addresses only for domain onion
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: using local addresses only for domain localhost
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: using local addresses only for domain invalid
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: using local addresses only for domain bind
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: using local addresses only for domain lan
Thu Oct  8 11:11:39 2020 daemon.warn dnsmasq[2836]: no servers found in /tmp/resolv.conf.auto, will retry
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: read /etc/hosts - 4 addresses
Thu Oct  8 11:11:39 2020 daemon.info dnsmasq[2836]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Thu Oct  8 11:11:39 2020 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Thu Oct  8 11:11:40 2020 daemon.info dnsmasq-dhcp[2836]: read /etc/ethers - 0 addresses
Thu Oct  8 11:11:40 2020 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Thu Oct  8 11:11:40 2020 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Thu Oct  8 11:11:40 2020 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Thu Oct  8 11:11:41 2020 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Thu Oct  8 11:11:42 2020 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Thu Oct  8 11:11:42 2020 daemon.notice netifd: radio0 (2205): Successfully initialized wpa_supplicant
Thu Oct  8 11:11:42 2020 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Thu Oct  8 11:11:42 2020 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Thu Oct  8 11:11:43 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 50:02:91:47:f5:3e
Thu Oct  8 11:11:43 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.217 50:02:91:47:f5:3e
Thu Oct  8 11:11:44 2020 user.notice ucitrack: Setting up /etc/config/mwan3 reload trigger for non-procd /etc/init.d/mwan3
Thu Oct  8 11:11:47 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 40:40:a7:9b:b7:ce
Thu Oct  8 11:11:47 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.173 40:40:a7:9b:b7:ce
Thu Oct  8 11:11:48 2020 daemon.notice procd: /etc/rc.d/S95done: killall: uqmi: no process killed
Thu Oct  8 11:11:50 2020 daemon.notice procd: /etc/rc.d/S96led: setting up led wifi
Thu Oct  8 11:11:51 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 60:01:94:2a:22:89
Thu Oct  8 11:11:51 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.170 60:01:94:2a:22:89
Thu Oct  8 11:11:52 2020 user.info : Sta config not set!!!!
Thu Oct  8 11:11:52 2020 daemon.notice procd: /etc/rc.d/S99gl_route_policy: uci: Entry not found
Thu Oct  8 11:11:54 2020 daemon.notice netifd: radio0 (3736): Successfully initialized wpa_supplicant
Thu Oct  8 11:11:55 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) f4:cf:a2:00:79:fe
Thu Oct  8 11:11:55 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.128 f4:cf:a2:00:79:fe
Thu Oct  8 11:11:55 2020 daemon.notice netifd: Interface 'wwan' is enabled
Thu Oct  8 11:11:59 2020 daemon.info procd: - init complete -
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 60:01:94:fb:87:dc
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.147 60:01:94:fb:87:dc
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.217 50:02:91:47:f5:3e
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.217 50:02:91:47:f5:3e Hot-Water-24
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.225 9c:2a:70:43:59:ed
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.225 9c:2a:70:43:59:ed DESKTOP-3FOTPE7
Thu Oct  8 11:11:59 2020 daemon.notice netifd: Network device 'wlan-sta' link is up
Thu Oct  8 11:11:59 2020 daemon.notice netifd: Interface 'wwan' has link connectivity
Thu Oct  8 11:11:59 2020 daemon.notice netifd: Interface 'wwan' is setting up now
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 60:01:94:2a:22:89
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.170 60:01:94:2a:22:89
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) f4:cf:a2:00:79:fe
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.128 f4:cf:a2:00:79:fe
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 40:40:a7:9b:b7:ce
Thu Oct  8 11:11:59 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.173 40:40:a7:9b:b7:ce
Thu Oct  8 11:11:59 2020 daemon.notice netifd: wwan (4065): udhcpc: started, v1.28.3
Thu Oct  8 11:12:00 2020 daemon.notice netifd: wwan (4065): udhcpc: sending discover
Thu Oct  8 11:12:03 2020 daemon.notice netifd: wwan (4065): udhcpc: sending discover
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) b8:27:eb:df:14:36
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.115 b8:27:eb:df:14:36
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.173 40:40:a7:9b:b7:ce
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.173 40:40:a7:9b:b7:ce android-48d7c2edbe9e4bec
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) b8:27:eb:2a:30:bd
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.167 b8:27:eb:2a:30:bd
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.225 9c:2a:70:43:59:ed
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.225 9c:2a:70:43:59:ed DESKTOP-3FOTPE7
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.217 50:02:91:47:f5:3e
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.217 50:02:91:47:f5:3e Hot-Water-24
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 60:01:94:fb:87:dc
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.147 60:01:94:fb:87:dc
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.170 60:01:94:2a:22:89
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.170 60:01:94:2a:22:89 WaterPumpRelay-97
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) f4:cf:a2:00:79:fe
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.128 f4:cf:a2:00:79:fe
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.128 f4:cf:a2:00:79:fe
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.128 f4:cf:a2:00:79:fe Ceiling-Light-3
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.147 60:01:94:fb:87:dc
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.147 60:01:94:fb:87:dc Top-Floor-Light-35
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.167 b8:27:eb:2a:30:bd
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.167 b8:27:eb:2a:30:bd raspberrypi
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.115 b8:27:eb:df:14:36
Thu Oct  8 11:12:03 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.115 b8:27:eb:df:14:36 domoticz
Thu Oct  8 11:12:04 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 7c:03:ab:b8:86:9e
Thu Oct  8 11:12:04 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.102 7c:03:ab:b8:86:9e
Thu Oct  8 11:12:04 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.102 7c:03:ab:b8:86:9e
Thu Oct  8 11:12:04 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.102 7c:03:ab:b8:86:9e
Thu Oct  8 11:12:05 2020 daemon.notice netifd: wwan (4065): udhcpc: sending select for 192.168.100.5
Thu Oct  8 11:12:05 2020 daemon.notice netifd: wwan (4065): udhcpc: lease of 192.168.100.5 obtained, lease time 259200
Thu Oct  8 11:12:05 2020 daemon.notice netifd: Interface 'wwan' is now up
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: reading /tmp/resolv.conf.auto
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using local addresses only for domain test
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using local addresses only for domain onion
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using local addresses only for domain localhost
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using local addresses only for domain invalid
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using local addresses only for domain bind
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using local addresses only for domain lan
Thu Oct  8 11:12:05 2020 daemon.info dnsmasq[2836]: using nameserver 192.168.100.1#53
Thu Oct  8 11:12:07 2020 user.info travelmate-[1.2.0]: interface 'wwan' on 'radio0' connected to uplink 'LakeToba2/-' (GL-MT300N-V2, OpenWrt 18.06.1 r7258-5eb055306f)
Thu Oct  8 11:19:57 2020 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Thu Oct  8 11:20:00 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Thu Oct  8 11:20:00 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP
Thu Oct  8 11:20:25 2020 daemon.info dnsmasq-dhcp[2836]: DHCPDISCOVER(br-lan) 2c:26:17:04:2b:6f
Thu Oct  8 11:20:25 2020 daemon.info dnsmasq-dhcp[2836]: DHCPOFFER(br-lan) 192.168.8.133 2c:26:17:04:2b:6f
Thu Oct  8 11:20:26 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.133 2c:26:17:04:2b:6f
Thu Oct  8 11:20:26 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.133 2c:26:17:04:2b:6f Oculus-Pacific-518b7d8f3c52724c
Thu Oct  8 11:20:56 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Thu Oct  8 11:20:56 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP
Thu Oct  8 11:21:40 2020 daemon.info dnsmasq-dhcp[2836]: DHCPREQUEST(br-lan) 192.168.8.118 00:21:5d:31:7f:06
Thu Oct  8 11:21:40 2020 daemon.info dnsmasq-dhcp[2836]: DHCPACK(br-lan) 192.168.8.118 00:21:5d:31:7f:06 DESKTOP
How many devices are connecting to your router now?
I see you are using repeater? What if you just use cable?
Seems you also installed travelmate. What if you use a stock firmware without any extra things.
Also can you get the network status by using “ifconfig”?
As mentioned in the first post. This how it looked after a fresh factory reset without any extra things and only one single device is connected. The average ping is between 50 and 100ms.
Then all the problems are gone. Ping: <1ms and high speed internet.
After factory reset (and setting for repeater):
root@GL-MT300N-V2:~# ifconfig
apcli0    Link encap:Ethernet  HWaddr E6:95:6E:04:2E:B1
          inet addr:192.168.100.9  Bcast:192.168.100.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
br-lan    Link encap:Ethernet  HWaddr E4:95:6E:44:2E:B1
          inet addr:192.168.8.1  Bcast:192.168.8.255  Mask:255.255.255.0
          RX packets:437140 errors:0 dropped:0 overruns:0 frame:0
          TX packets:523284 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:220815559 (210.5 MiB)  TX bytes:560501101 (534.5 MiB)
eth0      Link encap:Ethernet  HWaddr E4:95:6E:44:2E:B1
          inet6 addr: fe80::e695:6eff:fe44:2eb1/64 Scope:Link
          TX packets:23192 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:3428961 (3.2 MiB)
          Interrupt:5
eth0.1    Link encap:Ethernet  HWaddr E4:95:6E:44:2E:B1
          TX packets:21732 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:2839332 (2.7 MiB)
eth0.2    Link encap:Ethernet  HWaddr E4:95:6E:44:2E:B1
          TX packets:1446 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:494532 (482.9 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:934 errors:0 dropped:0 overruns:0 frame:0
          TX packets:934 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:78289 (76.4 KiB)  TX bytes:78289 (76.4 KiB)
ra0       Link encap:Ethernet  HWaddr E4:95:6E:44:2E:B1
          RX packets:509659 errors:1674 dropped:0 overruns:0 frame:0
          TX packets:550868 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:243888687 (232.5 MiB)  TX bytes:559289261 (533.3 MiB)
          Interrupt:6
Everything is changing constantly and it’s hard to reproduce. Sometimes i get average ping rates of 25ms (In rare occasions) to the MT300. Sometimes 300ms… and sometimes 50ms… (measured over an 1 minute time frame)
Sometimes i get speeds of only 2Mbps and sometimes 18Mbps. But always have a RSSI of >60dB.
After many hours of testing i found out that the GLinet router does not “like” my internal wifi card from my miniPC. If i ping my Wifi-Modem from my miniPC. I get ping times of constant 3ms. If i ping the GLinet router. I get numbers all over the place from 1ms to 150ms. (Both these test where made with only one single device connected)
When i add a external USB wifi dongle to my miniPC. Then i also get constant 1ms to the Glinet IF no other devices are connected.
Some results in different scenarios. Pinging from mini PC (USB wifi dongle) to Glinet router:
Only the miniPC is connected ( with new USB wifi dongle) to Glinet router without any traffic or load:
One device no traffic
After a second device (My Android phone) is connected it gets worse immediately (still no traffic):
Second deviced no traffic
Now i open a website on my android device:
open website on second device
In the syslog i only see DHCP requests and nothing suspicious. The average load of the router is around 4.
Do you know how much fun it is to open websites with a ping time of 1 second? Zero fun. I don’t know what else to do. What can i test more?
In contrast. When i connect my PC with the wifi-modem directly (without the MT300 in between). The ping times basically don’t go up. Even with two devices connected. And that’s how it should look like. Why this doesn’t work with my MT300?:
Might be useful to draw a picture of your network setup and where MT-300N fits in.
It’s kind of hard to follow what might be the problem
The above tests where done with this setup. All wireless connections.
Windows PC = miniPC
Not sure what is wrong but what if you do not use repeater, only use cable from the mini router to your main router?
Did you ever set up mac clone?
After some more testing…This might solve the problem:
I tried four different 2A power supplies so i thought that’s not the reason. BUT after i tried one more. Suddenly i don’t have problems any more. My connection is much more stable in every way.
After i knew it might be the powersupply. I solderd a 1000uF capacitor to the output of the old one which is a 12V to 5V converter (The repeater gets power from a solar system). And yeahaa. Live feels better with stable internet :smiley: (I am a hobbyist. So if that capacitor is a bad idea. Let me know)
Change of power supply/ Capacitor seemed to have fixed it. For now :grin:
The final setup (which was not the test setup earlier) runs now since three days without big problems: The GL-MT300N in combination with a USB WiFi (TL-WN722N) and a helical-dish antenna repeats the wifi to my house from an access point 1km away. I get an average signal of -61 dBm. (Only a small bush in between)
These are my ping-times now in my final setup (last 6 hours). Ping tests are running from a Raspberry Zero W which connects to the GL-MT300N via wifi:
I am happy with it. Big improvement to how it was before. The spikes appear when people use the internet. But it’s not really an issue.
Will keep observing but i hope the power supply was the issue.
Using a cable between mini router and main router. Then I get super fast speeds and the ping between the router and the device is around 10ms without any big hiccups (I still believe it should be 3ms or less). But i am happy with 10.
Never set up mac clone.
Seems it was just coincidence that it worked for while with the new power supply.
Now i am back to unusable high ping times since two days.
And again. These ping times i get after a fresh factory reset. No VPN… no USB wifi… just a fresh factory reset:
The hours i spent trying to get this this Glinet router to work are countless and devastating… weeks… I am done with that and frustrated.
For testing i bought a cheap 10USD extender from Tenda. And here we go. Works almost flawless. I won’t have VPN or routing with it. But at least i have internet and low ping rates and highb speeds!! The GL-MT300N failed to give me that.
I don’t know why it does not work for me. I love the idea of these Glinet devices. But i guess it doesn’t work for everyone.
