2021, gl-inet Firmware Firmware 3.211 Beta1, wrong translation
The right German translation for the English menu item “WIRELESS” is “DRAHTLOS” and not “KABELLOS”.
Are still reported on:
Thats possible to understand, a its wrong. The right translation in German is “Drahtlos”.
Perhaps its not so complicated to fix it.
Remark:
The full list of found and solved bugs, realisized asked product improvements and possible additional proposal for product improvements can be found on:
This issue has been fixed and will be automatically integrated in tomorrow’s Snapshot release.
Thats sounds great. We will check it.
If you can, please replace the Labeling “lokale Aktualisierung” by “Lokale Aktualisierung” of the german version of the english TAB “Local Upgrade”.
THX
Test result:
  • Fixed on tested version openwrt-ar750s3.211-1125 (or or before)
THX
Test result:
  • Not fixed in on tested version openwrt-ar750s3.211-1125
Beta2 fixes issues in the upgrade page
Test result:
  • The wrong translation are fixed on 3.211 Beta 2, 3 or 4:
THX ! 谢谢你 !
