248 Brovi E3372-325 on GL-AXT 1800 flashing red and green
When I plug the Brovi E3372-325 into the GL-AXT 1800, it only flashes red and green alternately and isn't displayed on the control panel. Assigning an IP address didn't help either.
What can I do?
It looks like your E3372-325 is also stuck in CD-ROM only mode.
You can refer to the following solution:
No, my E3372-325 is in HiLink mode.
The E3372 isn't recognized by the GL-AXT 1800 either.
What can I do, or which USB stick can I buy that will work flawlessly?
The issue mentioned in the first link I shared is related to HLink mode.
You can check whether your E3372-325 has received the firmware update that fixes this issue, as noted in the post.
If the problem persists, you may consider using our SIMPoYo uFi, which is compatible with our routers.
Is there also a compatible 5G stick?
This one is 5G, but it hasn’t been officially released for sale yet.
When will it be available?
It will probably be available at the end of Q2 or Q3. There isn’t a detailed timeline yet.
I ordered this 4G phone and have a question about data privacy regarding the SIM card.
Is it registered to the name of the delivery address?
What data is stored?
Is the IMEI number linked to the delivery address?
For after-sales support purposes, we only maintain essential information, such as the specific product model associated with your order number. Your personal information is not linked to any individual device, and it is impossible to retrieve personal data using only a device’s Serial Number (SN) or IMEI.
For more information, please refer to our Privacy Policy:
