Any Idea here of good 4G external antenna to work with your products ?
I have network problem here on the road , And need better reception, Only get around 2 bar at all time.
with your current antenna and Router ( GL-X750 )
How many bars do you get if you use a smartphone with the same carrier/SIM card?
Here is a thread about upgrading the GL-X750 antennas, with no clear benefit:
Just try 2 set of antenna I had from Aliexpress and 1 of them made the cut !
I now almost never drop signal and have good internet all over the area I am driving.
Guess my carrier really like the Band 4 and that the stock antenna just where not enough
This is the antenna from aliexpress
If I still DC , then I will look for a signal booster !
How many bars do you get now with the new antenna?
Well , It does not upgrade the BAR a lot , i think , i am now from mostly 2 bar , sometimes 3 bar from a mostly 2 bar.
But the reception never drop now ( was dropping at least 10 times per day before ) , I have 130 ping instead of 300 ish and I have reception on BAND 4 , 2050 ish . was not able to have clear band 4 reception before. Band 2 mostly before
so for me , this Antenna just fix all my problem , i try 2 other model that where not a big Mimo antenna and they did not work .
I have to say , I use the router in my car with a portable battery pack. and work on the road in a 100km range from the main city.
hope this can help !
