Spitz GL-X750 antennae upgrade
I’m based in the UK, and my Spitz GL-X750 indoor WiFi coverage is horrible, and LTE speeds not good at all. I understand the two external antennae are for Wifi (5GHz, 4dbi) and LTE (700M ~ 2.7GHz), while 2.4GHz is supported via the internal antenna.
Does anybody know which external antenna is which? I was thinking of updating them both with this Amazon.co.uk
Does anyone have experience with this and can share if it’s worth it at all? If I could get some guidance, I’m happy to share the results of the upgrade if it might help anyone
Both the antenna is for LTE. So pls get two LTE antenna for X750.
Thanks alzhao. So what’s the difference between the two antennae?
Also, how may I increase the 5Ghz coverage if the antenna is only internal?
LTE need two antenna for better signal. One is main and another is differential.
For 5G, the only way is to drill a hole and connect another SMA antenna.
Can this Amazon.co.uk be used as LTE antennae?
No that is for WiFi.
Just search LTE antenna in amazon and you will have a lot.
What is the DBI of the antennae currently installed on the device?
@alzhao can you please advise?
I am not sure. Sorry. But not high gain.
No, worries thanks. Do you think 10dbi B06XPYFZ55 on amazon.co.uk would suffice?
Sorry the link only links to amazon, not a product. Can you give link of the product directly?
The forum wouldn’t let me. On Amazon UK just search for B06XPYFZ55
It is correct. The antenna should be SMA male.
How did you get on? Any improvement in ‘LTE speeds’?
Did you make a hole for the wifi antenna?
I received US version with EP06-A modem. It has 3 antenna connectors. One is LTE, another is GPS
(EP06 has GPS) and middle one is differential. Differential wasn’t connected to anything.
GPS and LTE on the modem were connected. Are they connected to external SMA connectors?
If modem doesn’t acquire GPS fix will it work? I couldn’t lift PCB to see what underneath so
I do not know still what is connected to external SMAs. GPS and LTE? or LTE and 5G-WiFi?
Thanks
No, the middle connector is the GPS. You can see a screenshot from the EP06 manual here:
You should pick up two Taoglas TG.55.8113W antennas. They just came into the market, support band 71, and have about a 10dbi difference in signal from the stock antennas.
I just ordered these and will hopefully have them tomorrow. Thanks for the heads up on them!
I’ll report back and their performance.
@RichP curious to know how these antenna worked out for you
