Ability to re-route first level domens through vpn
Sometimes I rerouting specific traffic using first level domain (ru, rs, pl and others). In 4.8.3 everything works great, but after upgrade same configuration works, but it’s impossible to set it through web UI. Could you plese fix it?
To our knowledge, the Web Admin Panel has not officially supported using only top-level domains (TLDs), such as .ru, .rs, or .pl, as domain-based VPN policy rules:
We’ll record this as a feature request and submit it to the product team for evaluation.
I assume that I used it earlier, when no regexp check on front page. Right now this feature is works if I modify vpn config directly through ssh, but I can't fill this page because of checks. So feature already implemented on back, but changes are needed on front
Thanks for the additional details.
It is indeed possible to achieve this to some extent by modifying the IP set entries used by dnsmasq, as discussed here:
However, another kernel module involved in VPN policy routing does not yet fully support standalone TLD entries. Therefore, this request still needs to be evaluated by our product team.
