My GL-AP1300 (Cirrus) is running a Wireguard client, which is connected to a Wireguard endpoint on the Internet.
From this point, how do I access the router LAN from outside? I spent many hours setting static routes, adding firewall rules, etc. with no success.
Please note that I don’t want to run a Wireguard server on my router (I’m using 4G LTE with Carrier-grade NAT so I don’t have any public IP I can access from outside).
[Interface]
# Name = AWS Wireguard server
PrivateKey = [private key]
Address = 10.1.0.1/16
ListenPort = 51820
[Peer]
# Name = 4G router
PublicKey = [public key]
AllowedIPs = 10.1.0.2/32,10.1.1.1/24
As you can see, I use the 10.1.0.xxx range for Wireguard interfaces.
But the router LAN (the one I want to access) is in the 10.1.1.xxx range.
The Wireguard handshake is successful and from the Wireguard server, I can ping the Wireguard client (10.1.0.2). But I can’t access any machine in the 10.1.1.xxx LAN.
