I am using the AR300M and I am trying to install the Adguard home. After installing the plugin, it installs successfully. Then when I need to turn on adguard home a message appears stating " Missing API".
Any advises?
Any advises?
It is mentioned here.
But here you are
adguard home : Adguard Home is only supported in S1300, AP1300, MV1000, B2200. They should be installed by default. Some user want to install Adguard Home on AR750s. It may works but AR750s is not powerful enough. You should go to Application->plugins, refresh repo and install gl-agh-stats
