I’ve been testing different firmware version from 2.4 to 2.7. And the client just dropping connections with different reason from logs.
STA ac:ed:5c:21:9a:58 IEEE 802.11: disconnected due to excessive missing ACKs
IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
br-lan: port 2(wlan0) entered disabled state
This has been pretty unusable to my part. I saw reason that main router signal is weak but I also have tp-link mini router which is not disconnecting for days. And main router is only 2-3 meters away.
I’ve been testing gargoyle firmware for this router using NEx wt3020 firmware and its alot stable than gl-inet firmware and I found the UI tobe more user friendly. My only issue is the button reset is not working.
