Any way to get a proper certificate instead of a self-signed one on GL-AX1800 (Flint)?
I just got this router and I was quite surprised and disappointed to find a self-signed certificate in this router. Is there any way to get a proper certificate instead of a self-signed one on the GL-AX1800 (Flint) running the 4.2.0 firmware?
First, f/w 4.2.3-release5 is the latest for the Flint. Consider upgrading (GL GUI → System → Upgrade). More to the point, technically, yes noting:
  • Certificates expire usually just at the 1 year mark for a commercially sourced one.
  • LetsEncrypt is free.
  • You’ll need a domain name to assign to your Flint as a host.
    • There’s many free dynamic DNS providers (DynDNS/DDNS) available.
I haven’t set this up yet myself but you’ll need deSEC DDNS, LuCI, SSH access to install python3 to configure this particular solution:
Does that update add a proper certificate to the Flint? I haven’t updated because I like to see how devices perform with the stock firmware before updating. I know of let’s encrypt but this post was meant for a proper certificate from glinet itself, is there a way to get one? Why doesn’t this router come with a valid proper, non self-signed certificate?
… & said domain names for assigning certs are tied to host’s IP.
4.2.3-release5 is the new stock/stable build. You can always downgrade if something breaks (GL GUI → System → Upgrade → Local Upgrade). Future builds are going to be based on OpenWrt Linux 22.03 v the current builds of 21.02.
It’s your call, of course.
I never had this issue with any of the router brands I’ve had before this one so not sure how that explains anything. From my standpoint it’s a very big oversight for a network equipment company.
Go to any TLS enabled site/service of your choice & lookup the Validity Period.
Don’t be dishonest. Certificates have validity periods and no one is questioning that but I never had an invalid or SELF-SIGNED certificate when I visited the admin page of any other router I’ve owned.
I really wonder what gear you have had, because I see the following:
  • ISP provided router: NO SSL AT ALL!
  • HP gear: Self-signed
  • Zyxel gear: Self-signed
I’m not counting ISP’s routers. Personally linksys (the classic WRT54G on which I even installed openwrt way back in the day), tp-link and medialink. Never had issues with certificates with them.
Very likely those routers did not even have TLS/SSL on their web-interfaces at all. Yeay for sending the credentials to access your router plaintext to it.
OpenWRT recently (since 22.x) does by default do TLS/SSL with self-signed certificates. They rather have TLS/SSL with self-signed certificates protecting them then plaintext communication.
There's no easy way to provision a certificate that actually works without also doing some DNS work. Nobody is going to issue a certificate for https://192.168.0.1/. What I was going to do is use LetsEncrypt DNS-01 challenge to generate the certificate plus a free HE.net subdomain so I can create a _acme-challenge.axt1800.pvt.mynetwork.org TXT record and a axt1800.pvt.mynetwork.org A record. That way, I could then go to https://axt1800.pvt.mynetwork.org/ from any device without any warnings. I'd just need something to actually create the certificate on the device.
This [Script] Let's encrypt for GL.iNet router HTTPs access should work.
