I swear I installed and used this on beta 4.
If I refresh the package in GL-UI and search, I can try to install tcpdump
I
If I press install, it fails to install:
Package appears missing in LuCI and at the command line.
What have I broken, or is the package missing?
Simon
@dxf can you have a check of this issue?
dxf
3
I did a retest and found that Beta4 works properly
dxf
4
I found that tcpdump is missing in Beta8;
so you can SSH the command to add a base feeds
echo "src/gz openwrt_base https://downloads.openwrt.org/releases/21.02-SNAPSHOT/packages/arm_cortex-a7/base" >> /etc/opkg/distfeeds.conf
and then you can install tcpdump on gl-ui
Hello Mr Dengxinfa,
that works a treat, thank you very much.
Simon
Confirmed as still missing on the GL.iNet repo on 2022-05-24
Anyone able to install tcpdump? - #4 by dengxinfa works
