Have placed order for the device. While waiting the shipment, want to know if anyone has successfully set it up with new Visible wireless plan?
I have cudy router working with Visible, but I trust the gl inet’s design which is smaller and looks like has better heat dissipation. Also they have so many good wifi routers. So I want to give the new 5g router a try.
I tried GL-X3000 (Spitz AX) using 2 different Visible SIMs. I have Quectel RM520N-GL. I’m unable to get 2 different Visible SIMs to work in GL-X3000. Both of the 2 SIMs have already been activated using the Visible app, on a cell phone, for about 5 months now. Both of the 2 Visible SIMs successfully work in an Android Samsung A54 phone and a Samsung Note 9 phone. Both of the 2 Visible SIMs successfully work in a Cudy P5 and MOFI 4500 router. However, both of the 2 Visible SIMs are reporting “SIM Card Not Registered” when trying to connect in the Admin Panel Cellular using the GL-X3000 Spitz? I have tried many APN configurations with vzwinternet, vsblinternet, etcetera with no success. I’m using a Waveform 4X4 MIMO antenna. The Waveform MIMO is of course reporting excellent reception strength. I have tried both of the 2 SIM cards in both SIM 1 and SIM 2 slots on the GL-X3000 router. So, there is seemingly something in the GL-X3000 firmware or modem that is impeding the 2 SIMs ability to successfully register when being used in the GL-X3000 modem/router? Any info/insight/help would be greatly appreciated!
