I love the routers for the hardware, and I would probably order a few dozen tomorrow for a project we have, but unfortunately we haven’t been able to get a standard CC OpenWRT image to install yet. Unfortunately either BB or the packages in the GLI firmware do not work as well as a basic CC image.
I do this…
cd /tmp
wget GL.iNet download center
sysupgrade -n openwrt-clean-gl-ar150-1.0.bin
and get this…
Invalid image type.
Image check ‘platform_check_image’ failed.
I downloaded a couple times to be sure. I also even tried the AR150 bin from the trunk release (https://downloads.openwrt.org/snapshots/trunk/ar71xx/generic/openwrt-ar71xx-generic-gl-ar150-squashfs-sysupgrade.bin) and it gave the same error.
We are just looking for a standard CC image like you find available for all the other travel sized routers, like the TL-WR703N for example. With that router we are able to install the bin and then install the driver packages for the RT3070 chipset and we can connect a USB Wifi Adapter to it without a problem. On the AR150 with the standard BB based GLI firmware the same adapter will not work after installing the same driver packages.
I should clarify, the adapter is recognized as a wireless device, but it keeps resetting over and over as you can see from the syslog.
I starts out as phy0 and keeps disconnecting and redetecting… it will go on forever, phy2… phy3… phy85… phy99. We don’t have that problem on the couple routers we have tried using CC. I ensured the settings matched also and made sure the TX power was set to 18 just so it wouldn’t be a power draw issue.
I have not tried to compile images from source yet because I figured if the official images were invalid so would mine considering they are being built from the same source. Any insight you can offer on how how to get a standard CC (not BB and not GLI) image would be great. I would recommend that you try to get the AR150 in the official CC release. Your firmware is good for people who are trying to use it as a regular router, but there are probably just as many, if not more, that are trying to use it for development purposes and special projects using the regular OpenWRT distribution.
Tue Nov 1 23:12:32 2016 kern.info kernel: [ 65.010000] usb 1-1: USB disconnect, device number 11
Tue Nov 1 23:12:32 2016 kern.info kernel: [ 65.460000] usb 1-1: new high-speed USB device number 12 using ehci-platform
Tue Nov 1 23:12:32 2016 kern.info kernel: [ 65.760000] usb 1-1: reset high-speed USB device number 12 using ehci-platform
Tue Nov 1 23:12:33 2016 kern.info kernel: [ 65.920000] ieee80211 phy11: rt2x00_set_rt: Info - RT chipset 3071, rev 021c detected
Tue Nov 1 23:12:33 2016 kern.info kernel: [ 66.060000] ieee80211 phy11: rt2x00_set_rf: Info - RF chipset 0008 detected
Tue Nov 1 23:12:33 2016 kern.debug kernel: [ 66.100000] ieee80211 phy11: Selected rate control algorithm ‘minstrel_ht’
Tue Nov 1 23:12:33 2016 kern.info kernel: [ 66.130000] ieee80211 phy11: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
Tue Nov 1 23:12:33 2016 kern.info kernel: [ 66.160000] ieee80211 phy11: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Tue Nov 1 23:12:34 2016 kern.info kernel: [ 67.030000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Tue Nov 1 23:12:34 2016 kern.info kernel: [ 67.730000] usb 1-1: USB disconnect, device number 12
Tue Nov 1 23:12:35 2016 kern.info kernel: [ 68.180000] usb 1-1: new high-speed USB device number 13 using ehci-platform
Tue Nov 1 23:12:35 2016 kern.info kernel: [ 68.480000] usb 1-1: reset high-speed USB device number 13 using ehci-platform
Tue Nov 1 23:12:35 2016 kern.info kernel: [ 68.630000] ieee80211 phy12: rt2x00_set_rt: Info - RT chipset 3071, rev 021c detected
Tue Nov 1 23:12:35 2016 kern.info kernel: [ 68.700000] ieee80211 phy12: rt2x00_set_rf: Info - RF chipset 0008 detected
Tue Nov 1 23:12:35 2016 kern.debug kernel: [ 68.730000] ieee80211 phy12: Selected rate control algorithm ‘minstrel_ht’
Tue Nov 1 23:12:35 2016 kern.info kernel: [ 68.750000] ieee80211 phy12: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
Tue Nov 1 23:12:35 2016 kern.info kernel: [ 68.780000] ieee80211 phy12: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Tue Nov 1 23:12:36 2016 kern.info kernel: [ 69.460000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Tue Nov 1 23:12:37 2016 kern.info kernel: [ 69.870000] usb 1-1: USB disconnect, device number 13
Tue Nov 1 23:12:37 2016 kern.info kernel: [ 70.310000] usb 1-1: new high-speed USB device number 14 using ehci-platform
Tue Nov 1 23:12:37 2016 kern.info kernel: [ 70.620000] usb 1-1: reset high-speed USB device number 14 using ehci-platform
Tue Nov 1 23:12:37 2016 kern.info kernel: [ 70.780000] ieee80211 phy13: rt2x00_set_rt: Info - RT chipset 3071, rev 021c detected
Tue Nov 1 23:12:38 2016 kern.info kernel: [ 70.930000] ieee80211 phy13: rt2x00_set_rf: Info - RF chipset 0008 detected
Tue Nov 1 23:12:38 2016 kern.debug kernel: [ 70.980000] ieee80211 phy13: Selected rate control algorithm ‘minstrel_ht’
Tue Nov 1 23:12:38 2016 kern.info kernel: [ 71.030000] ieee80211 phy13: rt2x00lib_request_firmware: Info - Loading firmware file ‘rt2870.bin’
Tue Nov 1 23:12:38 2016 kern.info kernel: [ 71.070000] ieee80211 phy13: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
