I connect my ups usb cable to the related port of this router but it not recognized, because lsusb does not show it. The problem appears when powered via POE (netgear GS116LP) or via usb (5V, 2A).
The cable and the ups should be ok because they works with windows and other spare parts (ups, other cables…) I have, so the last thing remained is the router, hardware of software.
This is the dmesg:
[ 0.000000] Linux version 4.14.221 (glinet@ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Mon Feb 15 15:22:37 2021
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] MIPS: machine is GL.iNet GL-AR150
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat 805d3a90, node_mem_map 81006820
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyATH0,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 57436K/65536K available (4419K kernel code, 160K rwdata, 1008K rodata, 1252K init, 218K bss, 8100K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 51
[ 0.000000] CPU clock: 400.000 MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns
[ 0.000014] sched_clock: 32 bits at 200MHz, resolution 5ns, wraps every 10737418237ns
[ 0.007596] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.092173] pid_max: default: 32768 minimum: 301
[ 0.096903] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.102952] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.115762] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.123857] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.129776] pinctrl core: initialized pinctrl subsystem
[ 0.136429] NET: Registered protocol family 16
[ 0.176411] clocksource: Switched to clocksource MIPS
[ 0.181381] NET: Registered protocol family 2
[ 0.185534] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.190905] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.196964] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.203201] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.208644] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.214932] NET: Registered protocol family 1
[ 0.218818] PCI: CLS 0 bytes, default 32
[ 0.223000] Crashlog allocated RAM at address 0x3f00000
[ 0.228604] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.241253] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.245446] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.270551] io scheduler noop registered
[ 0.272920] io scheduler deadline registered (default)
[ 0.278659] pinctrl-single 18040028.pinmux: 64 pins at pa b8040028 size 8
[ 0.285051] gpio-export gpio-export: 1 gpio(s) exported
[ 0.290432] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.299131] 18020000.uart: ttyATH0 at MMIO 0x18020000 (irq = 9, base_baud = 1562500) is a AR933X UART
[ 0.307111] console [ttyATH0] enabled
[ 0.313843] bootconsole [early0] disabled
[ 0.333786] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[ 0.337541] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.343722] Creating 4 MTD partitions on "spi0.0":
[ 0.348550] 0x000000000000-0x000000040000 : "u-boot"
[ 0.354706] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.359989] 0x000000050000-0x000000ff0000 : "firmware"
[ 0.368795] 2 uimage-fw partitions found on MTD device firmware
[ 0.373267] Creating 2 MTD partitions on "firmware":
[ 0.378294] 0x000000000000-0x0000001d0000 : "kernel"
[ 0.384280] 0x0000001d0000-0x000000fa0000 : "rootfs"
[ 0.389252] mtd: device 4 (rootfs) set to be root filesystem
[ 0.393784] 1 squashfs-split partitions found on MTD device rootfs
[ 0.400020] 0x000000c00000-0x000000fa0000 : "rootfs_data"
[ 0.406513] 0x000000ff0000-0x000001000000 : "art"
[ 0.412092] libphy: Fixed MDIO Bus: probed
[ 0.747550] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
[ 1.426895] libphy: ag71xx_mdio: probed
[ 1.716487] mdio-bus.0:1f: Found an AR7240/AR9330 built-in switch
[ 1.721383] libphy: ar7240sw_mdio: probed
[ 1.770969] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[ 1.779474] eth1: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
[ 1.787553] NET: Registered protocol family 10
[ 1.797331] Segment Routing with IPv6
[ 1.799687] NET: Registered protocol family 17
[ 1.804040] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.816997] 8021q: 802.1Q VLAN Support v1.8
[ 2.158048] ag71xx 19000000.eth: connected to PHY at mdio-bus.0:1f:04 [uid=004dd041, driver=Generic PHY]
[ 2.167445] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
[ 2.179336] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.194630] Freeing unused kernel memory: 1252K
[ 2.197739] This architecture does not have kernel memory protection.
[ 2.546477] random: fast init done
[ 3.042698] init: Console is alive
[ 3.044980] init: - watchdog -
[ 6.149117] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.407756] usbcore: registered new interface driver usbfs
[ 6.411877] usbcore: registered new interface driver hub
[ 6.417300] usbcore: registered new device driver usb
[ 6.437607] exFAT: Version 1.2.9
[ 6.493130] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 6.512907] SCSI subsystem initialized
[ 6.523717] ehci-platform: EHCI generic platform driver
[ 6.527937] ehci-platform 1b000000.usb: EHCI Host Controller
[ 6.533180] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
[ 6.541161] ehci-platform 1b000000.usb: irq 3, io mem 0x1b000000
[ 6.576445] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
[ 6.582489] hub 1-0:1.0: USB hub found
[ 6.585415] hub 1-0:1.0: 1 port detected
[ 6.596503] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.605146] ohci-platform: OHCI generic platform driver
[ 6.614714] uhci_hcd: USB Universal Host Controller Interface driver
[ 6.629339] usbcore: registered new interface driver usb-storage
[ 6.638817] usbcore: registered new interface driver uas
[ 6.644145] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.660794] init: - preinit -
[ 6.825539] random: crng init done
[ 11.087409] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 12.167611] eth1: link up (1000Mbps/Full duplex)
[ 12.170852] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 12.826514] usb usb1-port1: connect-debounce failed
[ 14.682264] mount_root: loading kmods from internal overlay
[ 14.888121] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 14.906067] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 15.870624] jffs2: notice: (460) jffs2_build_xattr_subsystem: complete building xattr subsystem, 5 of xdatum (2 unchecked, 3 orphan) and 23 of xref (3 dead, 0 orphan) found.
[ 15.885922] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 15.898290] block: extroot: not configured
[ 15.956185] jffs2: notice: (458) jffs2_build_xattr_subsystem: complete building xattr subsystem, 5 of xdatum (2 unchecked, 3 orphan) and 23 of xref (3 dead, 0 orphan) found.
[ 16.455145] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 16.466268] block: extroot: not configured
[ 16.471441] mount_root: switching to jffs2 overlay
[ 16.672013] overlayfs: upper fs does not support tmpfile.
[ 16.687358] urandom-seed: Seeding with /etc/urandom.seed
[ 16.942904] eth1: link down
[ 16.973628] procd: - early -
[ 16.975351] procd: - watchdog -
[ 18.480941] procd: - watchdog -
[ 18.483407] procd: - ubus -
[ 18.988343] procd: - init -
[ 25.212743] kmodloader: loading kernel modules from /etc/modules.d/*
[ 25.328279] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 25.417238] tun: Universal TUN/TAP device driver, 1.6
[ 25.513640] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 25.599240] nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
[ 26.132572] urngd: v1.0.2 started.
[ 26.296583] Netfilter messages via NETLINK v0.30.
[ 26.323167] ip_set: protocol 6
[ 26.574276] Mirror/redirect action on
[ 26.663632] u32 classifier
[ 26.664915] input device check on
[ 26.668651] Actions configured
[ 26.807675] GACT probability on
[ 26.843439] Simple TC action Loaded
[ 27.032571] fuse init (API version 7.26)
[ 27.139995] usbcore: registered new interface driver cdc_acm
[ 27.144215] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 27.221335] usbcore: registered new interface driver cdc_wdm
[ 27.241479] Loading modules backported from Linux version v4.19.161-0-gdaefdc9eb24b
[ 27.247819] Backport generated by backports.git v4.19.161-1-0-g4bb568fe
[ 27.374606] Ebtables v2.0 registered
[ 27.405880] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 27.441703] usbcore: registered new interface driver ipheth
[ 28.014853] ctnetlink v0.93: registering with nfnetlink.
[ 28.757392] usbcore: registered new interface driver usbserial
[ 28.761973] usbcore: registered new interface driver usbserial_generic
[ 28.768576] usbserial: USB Serial support registered for generic
[ 28.824677] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[ 28.831810] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 29.101660] xt_time: kernel timezone is -0000
[ 29.120307] usbcore: registered new interface driver cdc_ether
[ 29.149043] usbcore: registered new interface driver cdc_ncm
[ 29.350619] usbcore: registered new interface driver cp210x
[ 29.354959] usbserial: USB Serial support registered for cp210x
[ 29.399530] usbcore: registered new interface driver huawei_cdc_ncm
[ 29.703583] PPP generic driver version 2.4.2
[ 29.728370] PPP MPPE Compression module registered
[ 29.745637] NET: Registered protocol family 24
[ 29.767869] usbcore: registered new interface driver qmi_wwan
[ 29.791499] usbcore: registered new interface driver rndis_host
[ 29.903214] usbcore: registered new interface driver sierra
[ 29.907654] usbserial: USB Serial support registered for Sierra USB modem
[ 29.936227] usbcore: registered new interface driver sierra_net
[ 30.167690] usbcore: registered new interface driver option
[ 30.172032] usbserial: USB Serial support registered for GSM modem (1-port)
[ 30.317396] usbcore: registered new interface driver rt2800usb
[ 30.410467] ath: EEPROM regdomain: 0x0
[ 30.410488] ath: EEPROM indicates default country code should be used
[ 30.410493] ath: doing EEPROM country->regdmn map search
[ 30.410524] ath: country maps to regdmn code: 0x3a
[ 30.410541] ath: Country alpha2 being used: US
[ 30.410547] ath: Regpair used: 0x3a
[ 30.432588] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 30.437282] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 30.521164] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 83.272083] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
[ 84.640131] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 86.352120] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 86.381454] eth1: link up (1000Mbps/Full duplex)
[ 86.387607] br-lan: port 1(eth1) entered blocking state
[ 86.391455] br-lan: port 1(eth1) entered disabled state
[ 86.397456] device eth1 entered promiscuous mode
[ 86.423492] br-lan: port 1(eth1) entered blocking state
[ 86.427354] br-lan: port 1(eth1) entered forwarding state
[ 86.530649] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 90.728721] eth0: link up (100Mbps/Full duplex)
[ 90.746606] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
What can I do/test? Thanks for any help!!!
