Device don’t have ART,please write the default ART first…
Oh!
Your ART data is lost and your device will not work properly even if you flush the firmware.
You erased the whole flash?
Please provide your MAC address, I will try to find your ART data in the database.
You can send the MAC address to my email: luochongjun@gl-inet.com
Oh no… that doesn’t sounds good. Yesterday at night, I tried the same flash with other gl-inet and then It… gave me the same error.
Yes. I have to erased the chip using a programmer to restoring uboot. Wich mac do you need? the one in the sticker in the cover?
When I get home in the afternoon I’ll send you the email.
Thank you SO MUCH!
How do you flash firmware, uboot web?
The first flash I used uboot web; but the light went off and I bricked it. Then I had to buy a programmer.
Doing so requires backing up the ART partition
Of course… now, I know… anyway, the problem was that the light went off.
hi guyz,
I had similar issue!
I provide u a link video about LED FLASHING …
Can u confirm that situation is similar too ?
VIdeo → https://streamable.com/
Thanks
the url is not complete
Not the same, flash using uboot via web. Check this:
https://docs.gl-inet.com/en/3/troubleshooting/debrick/
thanks for replaying me
But I tryed several times ,… but nothing
I have no imput to link GL to pc … ;(
I show you an image that’s confirm I can’t reach the input via Web… non IP no DNS no reacheable…
I restart the procedure…
1- safeboot - both led are in stop mode (green & red) on
2 Set your computer’s IP address to 192.168.1.2
no IP doesn’t appare
I’m LOOCKED
Already sent. Thanks!
But how do they to retrive data from macadress?
seams strange… from where you get information about macadress ? if gl not work properly?
It’s in the ART partition…
Word to the wise - always keep that one backed up…
Good news!! I have restored one! I forgot that I made a backup of flash; the one that were working ok (AR300m16), and I made a copy of the ART partition. First question: Can I use it with the new one and change the MAC? The printenv only give me some values:
stdin=serial
stdout=serial
stderr=serial
ethact=eth0
When I tried to enter in safe mode it says “Starting HTTP server in ip 0.0.0.0”. I added other variables to enter in safe mode (with setenv), and I entered (yeah!). Still it doesn’t boot, I need to execute the command “boot”.
I have one problem with the first line:
setenv bootargs '...'
This line has been copied from the image that booted. But it’s too long and my terminal doesnt let me write the full line.
Anyway, I supposed that if I update the uboot it would update the variables, but it doesn’t. Here goes the second question: Is there anyway to do that via ssh?
Thanks a lot.
EDIT: FIXED BOOT ARGS
ok… cant flash art.bin
* ART UPGRADING *
* DO NOT POWER OFF DEVICE! *
Executing: erase 0x9FFF0000 +0x10000; cp.b 0x80800000 0x9FFF0000 0x10000
Erasing flash...
First 0xff last 0xff sector size 0x10000 255
Erased 1 sectors
Copy to Flash... write addr: 9fff0000
Write failed, cross 16M is forbidden
flash.c[227] FIXME: rc=-1
## Error: HTTP ugrade failed!
I’m trying in /art.html and this is the error in the UART console.
You cannot update art.bin via http.
Do you have tftp? Check this doc
Hi! The two units nos are working. FIXED. At this time the two units are with the same mac, but using clone mac I changed one until I could flash.
Yes, I have already checked and when I write those commands in console I am having the same error.
