Recently updated an old AR300M to 4.3.6 (factory reset ofcourse) and i’m now unable to connect through the OpenVPN client (nord).
Here is the log output. Any ideas?
Sat Aug 12 16:10:46 2023 daemon.notice ovpnclient[9447]: VERIFY OK: depth=0, CN=au657.nordvpn.com
Sat Aug 12 16:10:47 2023 daemon.notice ovpnclient[9447]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Sat Aug 12 16:10:47 2023 daemon.notice ovpnclient[9447]: [au657.nordvpn.com] Peer Connection Initiated with [AF_INET]103.212.224.227:1194
Sat Aug 12 16:10:48 2023 daemon.notice ovpnclient[9447]: SENT CONTROL [au657.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)
Sat Aug 12 16:10:53 2023 daemon.notice ovpnclient[9447]: SENT CONTROL [au657.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)
Sat Aug 12 16:10:54 2023 daemon.notice ovpnclient[9447]: AUTH: Received control message: AUTH_FAILED
Sat Aug 12 16:10:54 2023 daemon.notice ovpnclient[9447]: SIGTERM[soft,auth-failure] received, process exiting
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section @forwarding[0] is disabled, ignoring section
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section @forwarding[1] is disabled, ignoring section
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section nat6 option ‘reload’ is not supported by fw4
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section vpn_server_policy option ‘reload’ is not supported by fw4
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section gls2s option ‘reload’ is not supported by fw4
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section gls2s specifies unreachable path ‘/var/etc/gls2s.include’, ignoring section
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Section glblock option ‘reload’ is not supported by fw4
Sat Aug 12 16:10:55 2023 daemon.notice netifd: ovpnclient (9791): [!] Automatically including ‘/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft’
Sat Aug 12 16:10:56 2023 daemon.notice netifd: ovpnclient (9791): DROP  all opt – in * out *  0.0.0.0/0  → 0.0.0.0/0   match-set GL_MAC_BLOCK src
Sat Aug 12 16:10:57 2023 daemon.notice netifd: ovpnclient (9791): Failed to parse json data: unexpected character
Sat Aug 12 16:10:57 2023 daemon.notice netifd: ovpnclient (9791): uci: Entry not found
Sat Aug 12 16:10:57 2023 daemon.notice netifd: ovpnclient (9791): cat: can’t open ‘/tmp/run/ovpn_resolved_ip’: No such file or directory
