AR750 SDcard share media - how to access ???
Recently about a month March/April2021 I noticed the updated firmware addesses the SMD and sdcards.
So I have read many post to try to access the SD card on the AR750 slate and still unable.
QUESTION :: Do I access the SD CARD from other devices using a URL address of the LAN URL address /http//:1921681*102/mnt
********* THIS WEBSITE LIMITS THE EXAMPLES SCREEN CAPTURE I CAN ADD AS EXAMPLES ***********
this did not help -----
AR750 SD card slot used to share media
I didn’t have to do anything for mine. I have a 128GB SD card, and it pretty much worked just by inserting it – it shows-up under the “Share” section of the main GL web interface. By default, it is read-only unless you check the “Writable” checkbox, and it is only accessible via the LAN side, not the WAN side, unless manually enabled – are you trying to access it from the LAN side or WAN side? Also, for me, the card shows-up under the “Settings” section, under the devices subsection (the devices icon – the second icon from the bottom, above the “Firmware” icon), which allows you to view the contents of the device.
My card was initially exFAT, which worked, although I eventually installed packages to re-partition and re-format it as EXT4.
OTHER USELESS LINKS THAT DID NOT HELP ::
****** .I AM LIMITED TO THE LINK I CAN USE *******
