Hello.
I have updated my AR750S with openwrt-ar750s-3.211-1214 beta3 and this time I kept the old configuration of openwrt-ar750s-3.211-1112 beta1.
I had to remove / reset all the policies I had because there was no internet and put them back. 30 seconds and no problem now, the policies work fine again.
But there is still the same error when updating the lists as in the previous firmware.
See:
The CLIENTS page resets every time the router is rebooted in this beta firmware. Before that did not happen.
How can I avoid this to keep all Clients’ devices?
Because I have a long list of devices to control, I have 1 free wifi network (that’s fine by me) and I have to slow down all of them when they connect.
Thanks
Hello. I don’t think it’s blocked because the other 2 packages.gz download fine.
It’s only packages-3.0 that is wrong.
If I try to download from a downloader it says Error HTTP 404
From Chrome
This XML file does not appear to have any style information associated with it. The document tree is shown below.
Error>
Code>NoSuchKey
Message>The specified key does not exist.
Key>releases/v19.07.8/packages-3.0/ath79/glinet/Packages.gz
RequestId>53CF673CV8XMC1JC
HostId>JCDAk034UvTAzsEehhUQ4nfnHHVFCCbYrnae8apZKlRjpJnBC55nQyyHf87AtX8O3pleMW1Y0Ds=
/Error>
And the same also happens with the 2 AR750 3.211-1112 beta1. EDIT: In AR750 now it’s OK, no problems when update from Luci.
But when I update from GL Web UI, I think there are the correct number of packages, right?
Look (AR750S 3.211-1214 beta3)
ok not today. that was not my intention. but I just wanted to know if that is possible to have all repos in a home server and not depend to the internet because I don’t have internet 24h at home so I just can doanload all repos from 3.211 when stable or next firmware v.4 when available.
Thank you. I will ask you how can I download all repos soon.
Bye
