Astrowarp "channel bonding technology"
From the Astrowarp announcement, I see the wording “With our innovative channel bonding technology, you can harness the power of multiple internet connections simultaneously, achieving up to 95% of their combined speed and throughput.”
However this is the only place I can find anything about this bonding technology. Is there any further documentation? Can someone clarify how to use or configure this feature?
I did find a “Test Guide” post with a link to a typical application of “Aggregation VPN” but that link is dead. Did the link aggregation feature get shut down?
You can refer to the guide below for configuration.
The content is a bit outdated, but the overall steps should still be the same:
  1. Create a Premium or Elite paid network on the AstroWarp.
  2. Add your router to this network.
  3. Configure the Exit Node as the Cloud Gateway.
Update: After checking with the product team, we confirmed that this feature is scheduled to be discontinued in mid-April. Therefore, it is no longer recommended for use.
