I recently reset my router. It now has firmware v 4.2.3 the setup of which is nothing like the previous version. I am unable to load my Nord Dedicated IP config, it just says ‘The client is starting, please wait…’. The log files looks like this:
“Tue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: Incoming Control Channel Authentication: Using 512 bit message hash ‘SHA512’ for HMAC authentication\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.16.205.4:1194\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: Socket Buffers: R=[163840->163840] S=[163840->163840]\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: UDP link local: (not bound)\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: UDP link remote: [AF_INET]185.16.205.4:1194\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: TLS: Initial packet from [AF_INET]185.16.205.4:1194, sid=37102137 3dd503be\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA8\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: VERIFY KU OK\nTue Aug 8 00:5l2:52 2023 daemon.notice ovpnclient[8213]: Validating certificate extended key usage\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: VERIFY EKU OK\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: VERIFY X509NAME OK: CN=uk889.nordvpn.com\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: VERIFY OKk: depth=0, CN=uk889.nordvpn.com\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512\nTue Aug 8 00:52:52 2023 daemon.notice ovpnclient[8213]: [uk889.nordvpn.com] Peer Connection Initiated with [AF_INET]185.16.205.4:1194\nTue Aug 8 00:52:54 2023 daemon.notice ovpnclient[8213]: SENT CONTROL [uk889.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)\nTue Aug 8 00:52:59 2023 daemon.notice ovpnclient[8213]: SENT CONTROL [uk889.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)\nTue Aug 8 00:52:59 2023 daemon.notice ovpnclient[8213]: AUTH: Received control message: AUTH_FAILED\nTue Aug 8 00:52:59 2023 daemon.notice ovpnclient[8213]: SIGTERM[soft,auth-failure] received, process exiting\n”
If I use the Nord app onmy tablet the dedicated IP works fine. Can anyone suggest what the problem is?
