Beginner Setup for Syncthing
So am wanting to test the use of Syncthing to serve as a poor mans personal cloud backup using the USB port of my Flint v1. I've installed the plugin from the applications menu but have no idea how I configure or start it. Have rebooted, no change. I expected there to be a new option in the expandable menu under Applications but nothing.
Unfortunately, I have to take away your expectations straight away. Addons that you install later never have a GUI within the GL GUI. If you are lucky, there is a GUI for luci - but for syncthing this isn't the case.
To get it running, you need to read a few documentations and try around:
https://github.com/brglng/syncthing-openwrt?tab=readme-ov-file
Maybe you can refer to this post
