Beryl 7 GL-MT3600BE - v4.8.7 broken with slow download speed, v4.8.5 works
I just unpacked my Beryl 7, set in repeater mode (connected to my normal wifi as a repeater, over wifi). I got almost full speeds when running, on the stock firmware 4.8.5. The UI prompted me to update to v 4.8.7, which I did. Immediately I could only get download speeds of 0.5mbps. Upload speeds were strangely not as affected, but went down to 50% from before.
Tried everything to see why it now didn’t run, including restarting the Beryl unit and forgetting the wifi and setting it up anew.
Nothing worked, so I decided to flash back to 4.8.5, and immediately the unit recovered back to full speed.
I’d like to raise awareness for this since I do intend on updating this unit someday, just not to 4.8.7, so I hope you can find what is wrong or I will eventually have to return the unit.
Kind regards,
Daniel
Could we possibly have more information?
If your client device is not connected to the router and is connected to the upstream WiFi network from the same location, what is the approximate speed?
How did you test the network speed when it was abnormal on firmware 4.8.7?
Is your PC or mobile phone connected to the router's LAN/2.4G/5G/mlo?
Are both wired and wireless client devices experiencing problems?
Does the router have VPN, Tailscale, Tor, ADG, or other similar functions enabled?
Are there any differences in router settings between firmware 4.8.5 and 4.8.7?
Thank you!
Sure!
About 150mbit both directions. Firmware 4.8.5 gets close enough to this (Usually somewhere 120-130mbit both directions, but sometimes reaching 150). Firmware 4.8.7 only reached 0.5 mbit downstream and ~80mbit upstream. The upstream wifi network is a mixed 2.4G/5G network from a Unifi U6 Lite. There are no special filters/QoS or similar in place further up in the network.
I tested using fast.com and other web-based services for speed testing, for all the reported results here. The results were consistent no matter the service. Laptop and router placements were the same between tests. As you can imagine, even browsing a normal website reveals that something is struggling when downstream is 0.5mbit.
From my connected laptop, I only have the 2.4G and 5G networks enabled and only connected via wireless. My laptop was connected to the 5G network.
I only tried wireless, since that will be my use-case.
No, this was only following the guide/wizard to setting it up as repeater. After that I changed the emitted SSID names, and then I did the speed test, followed by firmware upgrade and disappointment.
Not that I have made. When upgrading firmware I ticked the box to keep settings. When downgrading back to 4.8.5 I again ticked the box to keep settings.
This is indeed strange; we've run multiple tests locally but haven't been able to reproduce the problem.
Could you export your router backup configuration and send it to us for testing, or could we check it remotely via GoodCloud?
Thank you.
I'm encountering the same issue with v4.8.7. Downgrading to v4.8.5 works much better in repeater mode.
This does seem very strange.
Is it true that on firmware 4.8.7, the connection speed is very low when connecting to any upstream WiFi network?
If the router repeater is connected to the internet, will there be problems if the client device is connected to the LAN via a wired connection?
Will there be problems with the router's WAN Ethernet connection? Is the problem only with the repeater?
Could you provide us with some logs, router configuration information, and test environment details?
Yes.
For your other questions I didn’t test and sadly need to run it without possibility of trying the update again.
What commands would you like to see run? I believe I’ve already given you test environment details, but please specify what you would want to see and I’ll do my best to provide it.
It's unclear whether the repeater is the only issue.
Wired speed test data for comparison would be more helpful.
For example:
WAN Ethernet + LAN
WAN repeater + LAN
If we don't have the means to test the wired connection, we'd like to know if there are any differences in the repeater connection status across different firmware versions.
For example, wifi band, bandwidth, channel, etc.
If possible, we would like to see the return result of the following command when speed tests show abnormal and normal:
Pre-command operations:
cat /proc/kmsg &
echo 8 > /proc/sys/kernel/printk
mwctl ra0 show stainfo // Used to view terminal connection information, rate negotiation, signal strength, etc. (This command is not interface-specific)
mwctl ra0 show mibbucket // Used to view current band environmental interference. This command requires multiple dumps to check for errors (This command is interface-specific, ra0-2G, rai0-5G)
mwctl ra0 show stainfo=ap // Used to view connection information, rate negotiation, signal strength, etc. between the AP and the upstream device when the AP is used as a downstream device (This command is not interface-specific)
If possible, you can also send me the log via private message.
Thank you very much.
I’m having the same issue. Speeds are slow out of the box. I loaded 4.8.5 but still getting slow speeds. Directly from the another router Im getting over 400mbps but when I have the beryl as a repeater, Im only getting about 25mbps which is crazy slow. Any tips or settings you used?
What frequency band and channel does the repeater use to connect to the upstream WiFi network?
Is it 5G WiFi?
Can you access the router via SSH and execute the following command:
cat /proc/kmsg &
What is the LAN speed test result if you connect the router via a wired connection?
Is the upstream WiFi your home WiFi or a public WiFi network?
If you connect the router to other WiFi networks, will the speed also be low?
Im a newbie and not a technical cs wiz. Im not sure how I can run those scripts. Do I have to install a program to do so? Im running home wifi . Don’t have access to connect to wired connection since all my devices do not have Ethernet port.
OK.
Sorry.
If so, would you be willing to bind your router to Goodcoud and then share your router with technical support so that we can remotely check this information?
Please refer to the link for steps on binding your GoodCloud account:
If possible, please send me the router's MAC address and management password privately.
I appear to have a related Beryl 7 repeater issue, although in my case 4.8.5 is also affected.
I have isolated it fairly extensively: direct client to the upstream WLAN gets ~200–230 Mbps, while Beryl repeater download collapses to ~1–10 Mbps with upload around ~300 Mbps. The problem remains with a wired LAN client and Beryl AP Wi-Fi disabled, is unaffected by HNAT on/off, and produces ~6–15 second latency even to the first-hop gateway under downstream load. The same Beryl works normally (~129 Mbps down) when using a phone hotspot as the upstream.
This therefore looks more like an upstream-WLAN / MediaTek STA interoperability issue than the 4.8.7-specific regression.
I have sent the full test results and diagnostics privately to GL.iNet support and can collect additional driver-level logs the next time I have access to the affected WLAN.
I’m concerned this issue may still be unresolved in firmware 4.9.0. I’m experiencing very similar, severe repeater performance problems with my Beryl 7 and have documented extensive testing here:
Beryl 7 (4.9.0): Severe repeater speed issues, wired WAN works normally
Is GL.iNet actively investigating this, and is there an expected firmware fix? Reliable repeater functionality is the primary reason I purchased this travel router. At this point, I’m uncertain whether to pursue a replacement, downgrade firmware, or return the device entirely.
We have already replied in the separate topic you created. Let's continue the discussion there:
