Hello team,
I’m experiencing severe and inconsistent download speeds using the Beryl 7 in repeater mode with my Xfinity gateway. I’ve spent considerable time testing both Wi-Fi bands, different security modes, wired versus wireless clients, and collecting SSH diagnostics.
This appears similar to the issues reported in this thread, although I’m running firmware 4.9.0.
I’m trying to determine whether this is a firmware/MediaTek interoperability problem or a defective unit.
Configuration
Router: GL.iNet Beryl 7 (GL-MT3600BE)
Firmware: 4.9.0, factory reset completed
Upstream: Xfinity gateway, tested on both 2.4 GHz and 5 GHz
Security: Initially WPA3-Personal; subsequently tested WPA2
Clients: Mac laptop via Ethernet LAN and Beryl 2.4/5 GHz Wi-Fi
Speed tests: Repeated fast(.)com measurements
VPN: Disabled throughout diagnostics, including AmneziaWG
Other diagnostics: SSH, iwinfo, iw, logread, dmesg, mwctl, top
Test results
| Connection | Download speed |
| Ethernet WAN → Beryl LAN | ~130 Mbps |
| Xfinity 5 GHz repeater → Beryl Wi-Fi | As low as ~5 Mbps |
| Xfinity 5 GHz repeater → Beryl LAN | ~27 Mbps |
| Xfinity 2.4 GHz repeater → Beryl LAN | ~14–160 Mbps, highly inconsistent |
| Xfinity 2.4 GHz repeater → Beryl 2.4 GHz Wi-Fi | ~33–47 Mbps |
| Xfinity 2.4 GHz repeater → Beryl 5 GHz Wi-Fi | ~53 Mbps |
| Xfinity repeater with WPA2 | ~13–20 Mbps |
| Phone hotspot → Beryl repeater | 2.2 Mbps (inconclusive) |
The phone hotspot’s own cellular connection was only reaching ~2.6 Mbps at the time, so that test doesn’t establish whether other upstream networks are affected.
The 2.4 GHz repeater occasionally achieved 120–160 Mbps over wired LAN, but performance was inconsistent and frequently much slower.
The important distinction is that Ethernet WAN works normally, while the wireless repeater uplink produces severe and variable speed degradation, including when the client is wired.
SSH diagnostics
During a 2.4 GHz upstream connection, iwinfo reported:
Interface: apcli0
Upstream SSID: Gophers
Channel: 11
Signal: approximately -28 to -35 dBm
Link quality: 70/70
Reported bit rate: 154.8 Mbit/s
Security: WPA3-SAE (CCMP)
Hardware: 14C3:7993 (MediaTek MT7993)
iw dev apcli0 station dump showed negotiated TX rates around 77–129 Mbps and RX rates around 206–287 Mbps in sampled connections, along with substantial TX retries and failures.
The kernel/repeater log also captured an actual disconnect/reconnect sequence:
21:51:06: apcli0 enabled and connected to upstream.
21:51:32: MediaTek driver reported wdev is null! errors.
21:51:35: Repeater disconnected.
21:51:38: Repeater reconnected.
Relevant driver error:
7993@ERROR.RA,ra0,UniCmdSetRecSecPnInfo() 6006: wdev is null!
The error occurred twice around the disconnect sequence. I don’t know whether it’s causal or incidental.
Additional diagnostics:
CPU was approximately 97% idle during testing, making CPU saturation unlikely.
mwctl ra0 show stainfo=ap returned only ap.
mwctl ra0 show mibbucket produced no output.
Strong signal strength did not correspond to consistently good throughput.
What testing has narrowed down
VPN overhead: Unlikely. VPN was disabled, including AmneziaWG.
General WAN/router throughput: Unlikely. Wired WAN achieved ~130 Mbps.
Beryl client Wi-Fi alone: Unlikely to explain everything. A wired LAN client also experienced poor repeater performance.
Weak upstream signal: Unlikely during the captured 2.4 GHz diagnostics (-28 to -35 dBm, 70/70 link quality).
WPA3-specific problem: Unlikely to be the sole cause. Changing Xfinity to WPA2 still produced ~13–20 Mbps.
CPU saturation: Unlikely. CPU was ~97% idle.
Corrupt configuration: Less likely after a factory reset, although not completely excluded.
Specific upstream compatibility: Still possible. The hotspot test was limited by poor cellular throughput.
Firmware regression or defective hardware: Not yet distinguished. I haven’t completed a controlled comparison against 4.8.5.
The main suspicion is MediaTek MT7993 repeater/STATION interoperability with the upstream Xfinity Wi-Fi, possibly involving rate negotiation, retries, or driver behavior.
Questions for GL.iNet support
Is this a known MT7993 repeater issue on firmware 4.9.0, particularly with Xfinity gateways?
Are the wdev is null! errors and repeater disconnects expected, or do they indicate a driver fault?
Are there updated mwctl commands or driver-level diagnostics appropriate for 4.9.0? The commands suggested in the earlier thread aren’t returning useful data.
Would testing 4.8.5 or another firmware branch help isolate a regression?
Based on these results, would GL.iNet recommend a firmware fix, different Wi-Fi settings, or a hardware replacement?
I can provide complete SSH logs and additional controlled tests if needed. I’d particularly appreciate guidance on distinguishing a firmware/driver issue from a defective unit before pursuing an RMA.
Thank you for taking a look.
