I have a wireguard vpn setup with one beryl (server) at home and one beryl (client) that I bring with me.
I have DNS set up and it has been working fine the last 3 months until today.
I do not think it is the server router because my vpn config works when testing it on my phone over LTE.
It also may be a problem with the wifi I am using, as the setup works fine when I connect the client router through a hotspot on my phone. It is only when I connect through the apt wifi that the vpn does not connect.
Edit: It also works fine when I setup the wireguard client with Mullvad
Here is the system log right after I click 'Connect" on the VPN tab for the client router:
Mon Jan 2 20:42:47 2023 daemon.info dnsmasq-dhcp[10007]: read /etc/ethers - 0 addresses
Mon Jan 2 20:42:50 2023 user.notice wiregaurd: client stop completed, del glwg.lock
Mon Jan 2 20:42:51 2023 user.info : output={"code":-3,"cloud_enable":false,"check_status":false,"rtty_ssh":true,"rtty_web":true,"serverzone":"","serverzones":["Europe","America","Asia Pacific","China"],"name":"rda107e","username":"","email":"","bindtime":""}
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Mon Jan 2 20:44:20 2023 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Mon Jan 2 20:44:21 2023 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Mon Jan 2 20:44:21 2023 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Mon Jan 2 20:44:25 2023 daemon.err uhttpd[15802]: bind(): Address in use
Mon Jan 2 20:45:50 2023 user.debug : ------ss-redir is not running!------
Mon Jan 2 20:45:50 2023 user.notice wireguard: wireguard client start
Mon Jan 2 20:45:51 2023 daemon.info dnsmasq[10007]: exiting on receipt of SIGTERM
Mon Jan 2 20:45:52 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Jan 2 20:45:52 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: started, version 2.80 cachesize 150
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: DNS service limited to local subnets
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq-dhcp[19641]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using local addresses only for domain test
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using local addresses only for domain onion
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using local addresses only for domain localhost
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using local addresses only for domain invalid
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using local addresses only for domain bind
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using local addresses only for domain lan
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: reading /tmp/resolv.conf.vpn
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: using nameserver 64.6.64.6#53
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: read /etc/hosts - 4 addresses
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq[19641]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jan 2 20:45:52 2023 daemon.info dnsmasq-dhcp[19641]: read /etc/ethers - 0 addresses
Mon Jan 2 20:45:56 2023 user.info mwan3rtmon[2599]: Detect rtchange event.
Mon Jan 2 20:45:56 2023 user.notice wiregaurd: client start completed, del glwg.lock
Mon Jan 2 20:50:02 2023 user.notice wireguard: wireguard client stop
Mon Jan 2 20:50:03 2023 daemon.info dnsmasq[19641]: exiting on receipt of SIGTERM
Mon Jan 2 20:50:03 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Jan 2 20:50:03 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: started, version 2.80 cachesize 150
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: DNS service limited to local subnets
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq-dhcp[30517]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using local addresses only for domain test
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using local addresses only for domain onion
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using local addresses only for domain localhost
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using local addresses only for domain invalid
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using local addresses only for domain bind
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using local addresses only for domain lan
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: reading /tmp/resolv.conf.auto
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: using nameserver 192.168.100.1#53
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: read /etc/hosts - 4 addresses
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq[30517]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jan 2 20:50:04 2023 daemon.info dnsmasq-dhcp[30517]: read /etc/ethers - 0 addresses
Mon Jan 2 20:50:07 2023 user.notice wiregaurd: client stop completed, del glwg.lock
Mon Jan 2 20:50:46 2023 user.debug : ------ss-redir is not running!------
Mon Jan 2 20:50:46 2023 user.notice wireguard: wireguard client start
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[30517]: exiting on receipt of SIGTERM
Mon Jan 2 20:50:47 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Mon Jan 2 20:50:47 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: started, version 2.80 cachesize 150
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: DNS service limited to local subnets
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq-dhcp[32756]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using local addresses only for domain test
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using local addresses only for domain onion
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using local addresses only for domain localhost
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using local addresses only for domain invalid
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using local addresses only for domain bind
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using local addresses only for domain lan
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: reading /tmp/resolv.conf.vpn
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: using nameserver 64.6.64.6#53
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: read /etc/hosts - 4 addresses
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq[32756]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Jan 2 20:50:47 2023 daemon.info dnsmasq-dhcp[32756]: read /etc/ethers - 0 addresses
Mon Jan 2 20:50:51 2023 user.info mwan3rtmon[2599]: Detect rtchange event.
Mon Jan 2 20:50:51 2023 user.notice wiregaurd: client start completed, del glwg.lock
