Brume 2 on Omada EcoSystem
Hi All,
Here is my current Omada setup:ISP Gateway → ER605 router → SG2210MP switch → SG2210P switch → Brume 2 (WAN port to Port 7 of SG2210P switch).
The Brume 2 has a WireGuard client (NordVPN) set up and would like it to be utilized by VLAN 70 (192.168.70.1/24), and I’m assuming this would be a Router-on-a-Stick configuration where all traffic is routed through the Brume 2’s WAN port. So far I’ve had no luck in properly configuring this.
Done the following:
-Given Static IP to Brume 2: 192.168.70.4
-Added 70 to the VLAN ID in Brume 2 interface
-Updated Port 7 settings on the SG2210P switch to tag VLAN 70
-Played around with Policy modes under VPN Dashboard
Any feedback appreciated.
Please create a dedicated firewall zone for VLAN 70.
After that, you’ll be able to find this firewall zone under VPN Dashboard → Policy Mode → From → Connection Type, and assign it to pass through the VPN, while other traffic continues to go through the WAN.
You can refer to this:
