hi,
i got a brumeW + 8GB tf card, i use youtube-dl and wget to dnld videos and webpages.
I wanna share it out as samba so I can use windows’s explorer’s copy/paste (becoz then i
can use teracopy to verify the file).
but brumeW’s tf mount point is not the same as I found on website.
(ntfs formatted)
my tf is mount at
/mnt/Microsoft Basic Data
root@GL-MV1000:/mnt/Microsoft Basic Data#
instead of the /dev/sda? as mentioned in the manual.
also, i don’t know where is the 8GB emmc of burme located.
root@GL-MV1000:/# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 20.0M 20.0M 0 100% /rom
tmpfs 499.5M 756.0K 498.7M 0% /tmp
/dev/loop0 490.3M 175.3M 217.0M 45% /overlay
overlayfs:/overlay 490.3M 175.3M 217.0M 45% /
tmpfs 512.0K 0 512.0K 0% /dev
df: /mnt/Microsoft\040Basic\040Data: No such file or directory
/dev/mmcblk0p3 6.6G 1.1G 5.1G 18% /data
root@GL-MV1000:/#
^-- i guess is the /dev/mmcblk0p3?
then how the hell I can share this as a samba?
the manual didn’t mention, also when i install plugins, it
keep telling me i have only xx MB, clearly the plugins are not
installing to this /data. then what’s the use of this 8GB emmc?
thank you.
