While waiting for something new to be enabled on your router, you could always just point your router to your local NTS server using NTP and get on down the road.
I don't have local server. And no ability to get some. Because I have only 2 laptops and phone.
I think it is better that Gl.iNet will make this official. For example Chrony is tiny. If they don't want to use chrony - ntsproxy or ntpsec should do the trick. But they must be built into firmware.
If you afraid of getting one fail point with cloud-based time here is more NTS providers:
I don’t have my MT3000 out, but they do have chrony-nts available for the flint3 in the repo. Should be easy enough to add yourself. It is under Applications, Plug-Ins. You will need to configure via CLI as there is not a LuCi package for it in the repo. Apologies if this package is not in the MT3000 repo.
The MT3000 warehouse already has the plug-in chrony-nts.
Install chrony-nts
opkg update && opkg install chrony-nts
Configure nts services
uci set chrony.@pool[0].hostname='time.cloudflare.com'
uci set chrony.@pool[0].iburst='1'
uci set chrony.@pool[0].nts='1'
uci set chrony.@nts[0]=nts
uci set chrony.@nts[0].systemcerts='yes'
uci commit chrony
Stop and disable the default sysntpd, and enable and start chronyd
Regular NTP is generally useless. It is like using HTTP instead of HTTPS. C'mon it is 2025.
I personally had situations (i was traveling), when ISP intercepted NTP when it detected DoT to prevent user from bypassing DNS based blocking.
GL team should force NTS by default. I don't think even other options should be.
Actually, even plain DNS is bad. Because, once more, there are some ISPs who abuse their power and record/intercept such connections. By the way, I will open separate request for encrypted DNS by default.
Callign NTP useless indicated a very myopic view of the world. Lots of us support larger networks as part of our day job. NTP is still the. most ubiquitous protocol in use for syncing time. DNS is the same way. Once you get into enterprises, and even more so OT environments, newer protocols are often not supported.
I understand your sentiment, but the world is much larger than your view suggests.
I am managing two AMD EPYC servers. They are located physically in my house. So...
Mostly, my servers used for my personal website, email and Tor nodes
And this is extremely bad. Because for example my ISP after looking through traffic, tried to kill my web-tunnel moat by spoofing NTP.
So, luckily, I am Linux user (both servers and desktop) so installing Crony wasn't hard.
But my main idea of post is that using unencrypted protocols will (it is a matter of time when exactly) cause you trouble. At least you will need to blindly trust your ISP not to poison or MITM anything.
Moreover, back to routers. Crappy networks uses DNS MITM (and some MITM port 80 and NTP) to enforce Captive Login to make it "unbypassable" (won't help, i even have script against such network tricks). Another situation is hotel/ship/college crappy network filters that uses same tricks to block even unknown VPN IP.
Generally it will be excellent if everything will be routed through TLS. It will make life for censors and attackers much harder.
Not everyone who uses GL is using them just at home. But even for home users, if they set a default as you suggest and things don’t work quite right - users will be calling GL support for help. However, if they simply use commonly supported protocols, especially like legacy DNS rather than introducing another point of failure with another provide, it can head off headaches for all involved. If your ISP needs you to use their DNS for account registration (cable modem providers often do this) using one of their internal dns servers, and it fails because of a non-standard default setting on equipment, who will they call? Making it available for people like you to change to secure is the right answer, but setting all of these defaults would be a mistake imo. This is why I said your view on this seemed limited. You are only looking at it from a technical end-user PoV only.
