Can not set Tailscale as an Exit Node
I have setup Tailscale however there is no option to set router itself as an "Exit Node".
I searched the forum and there are multiple solutions, including setting up cron jobs or editing config files, all which have their own issues.
Can you please add this to the GUI.
Thank you.
Support to enable the exit node of the Tailscale Client of GL GUI, this task is evaluating and going to develop soon, kindly await.
Update: whether if support the exit node of the Tailscale Client of GL GUI, now is still evaluate on PM level, have not import to develop process, since GL is developing own site to site features in GL router firmware. If require using Tailscale exit node, please follow this thread to enable the exit node feature for now:
Thank you for the update. I look forward to seeing the feature implemented.
